Question about my Bmw suspension - BMW Forum - BimmerWerkz.com
Old 10-19-2012, 08:45 AM   #1 (permalink)
Car: 92' 325i/5.0
1992 318i is on a distinguished road
Question Question about my Bmw suspension
My 318i needs news stock springs because the steering wheels shakes when ever i go 45+ could there be anything else that could cause this? Is there any good sites where i could buy springs for my 318i and i wasn't sure about this but can all E36 or most E36 parts work for my 1992 318i sedan?
1992 318i is offline   Reply With Quote
Old 10-19-2012, 11:44 AM   #2 (permalink)
Car: 92' 325i/5.0
The front and back wheels have a sight tilt at the top inward i mean the whole wheel is tilted its just they go inward at the top and outward at the bottom. I just dont know a easy way to say it.
Old 10-19-2012, 01:48 PM   #3 (permalink)
PicksBimmers is on a distinguished road
I had a similar problem with the front end on my '94. U should have the lower control arm bushings and ball joints looked at as that is most likely the problem and not the springs or shocks. These bushing do wear out. Most BMW's have a noticeable negative camber. After the front end is fixed you should have the alignment checked and set to factory specs.
PicksBimmers is offline   Reply With Quote
Old 10-19-2012, 01:52 PM   #4 (permalink)
Car: 92' 325i/5.0
Yeah that sounds like a good idea have to look at too, I've taken it to a shop and you could move the springs while they were on the car ( just the front springs though) But I will check out what you mentioned.
Old 10-19-2012, 02:07 PM   #5 (permalink)
Good luck. Here is a source that might help you in case you have not seen yet. RealOEM.com Online BMW Parts Catalog No the page click on "click Here" . Then put the last 7 digits of VIN, like AB0000, in the Serial number box and click search. This will bring up your car. Click on "Browse Parts" at bottom. Look around and it will get you nice pics of all the parts along with part numbers some avg costs. Nice for just seeing how things go together.
Old 10-19-2012, 07:08 PM   #6 (permalink)
Car: 92' 325i/5.0
Thanks for the information, I'll have to check it out.
Old 10-20-2012, 01:41 AM   #7 (permalink)
Lord Vader's Avatar
Car: 1998 E36 328i
If your able to move your springs then check your spring perch. May need replacement. Not common, but possible.
Click HERE to see my E36 Blog
suspension question ? jetjoe 3-Series (E36) 1 04-09-2011 12:37 PM
New guy suspension question cdc 1,6,7,8 - Series and Mini Cooper 2 12-10-2008 02:49 PM
Suspension question paplip 5-Series (E12,E28, E34, E39, E60) 8 03-31-2008 04:13 PM
KW suspension question nos 3-Series (E36) 3 11-22-2005 12:58 PM
Suspension Question corbeledg 3-Series (E46, E90) 7 04-13-2005 02:33 PM
