Question About Going Up A Steep Hill - BMW Forum - BimmerWerkz.com
Old 10-15-2004, 03:04 PM   #1 (permalink)
ultraviolet353 is an unknown quantity at this point
I have a '94 318 is automatic. When I go up a steep hill I am always in Drive, but I tried 3rd gear yesterday and it seemes I had more power--should I use 3rd for steep hills. Also, I know when you have an automatic most people keep it in Drive all the time but technically what driving scenarios are 1st, 2nd, and 3rd used for in an automatic.
ultraviolet353 is offline   Reply With Quote
Old 10-15-2004, 03:10 PM   #2 (permalink)
ex owner/admin
Furious's Avatar
usually thats why they had those gears there, steep hill gear is usually the 2nd gear, but depending on speed you can use 3rd gear,, the obvious reason that you felt more power is because the engine holds a higher RPM, where the power is, instead of changing into a higher gear and bogging the car.
Old 10-15-2004, 10:53 PM   #3 (permalink)
Car: 2008 128i
3 while in auto mode is also sport mode. which keeps the rpms a bit higher and (i could be wrong) sharpen throttle response.
2008 128i Jetblack
Old 10-16-2004, 12:54 AM   #4 (permalink)
so if you were to defoine 1st, 2nd, 3rd--in automatic, what would it be?
Old 10-16-2004, 01:28 AM   #5 (permalink)
Brian325i is an unknown quantity at this point
Don't know about automatics but when I go up a hill I'm usually at 3500rpms or higher...and that gives me plenty of power.
Brian325i is offline   Reply With Quote
Old 10-16-2004, 09:56 AM   #6 (permalink)
quality
Delmarco's Avatar
I'm more confused than when he first posed the question. What is "bogging" the car?
They way I've seen it from the drivers seat is,
D in M mode = I've heard this is equivalent to 4th gear in M mode, but in my experiments the car seems to drive similar to when in 3rd in M mode. I'm not completely sure about this arrangement.
3rd in M mode = burning more gas+driving at higher RPM = faster accelaration, quicker speeds, best for racing or accelerating on flat, smooth terrain.
2nd in M mode = Gives more power to push uphill, I'm not sure what is happening under the hood but I believe it gives more push power and less emphasis on speed or acceleration.
1st in M mode = For steep almost vertical downhills. Thats all I know about this arrangement
If you set your car to D in A mode the car will shift between all these modes automatically. However the main difference between A and M modes seem to be Machine (car doing it) VS. Man (you doing it).
Another Airbag Light Question storme 3-Series (E46, E90) 8 11-21-2005 01:01 PM
Ready To Buy '05 330...but Have A Question... Pitt66 3-Series (E46, E90) 15 03-09-2005 09:02 PM
Just got my 320i: Small question harpax 3-Series (E46, E90) 18 06-17-2004 04:24 PM
info center in the gauge cluster question audiosolstice 1,6,7,8 - Series and Mini Cooper 3 04-30-2004 02:58 AM
