Q about everything that holds the front wheels on - BMW Forum - BimmerWerkz.com
Old 04-23-2004, 09:09 PM   #1 (permalink)
Threadkiller
bitcore's Avatar
Let me start off: I drive this car HARD. The suspension also gets a hefty workout because the roads around here suck, and I've done some accidental mean things to it (like go over a long hump really hard... rail-road tracks at a moderate speed) and I drive like I'm auto crossing or running from the police. So there's obviously been some hefty wear going on.
Ok, I know I have some problems and a few failing\broken parts already, or at least something is loose. Tonight I hit a huge hump and afterwards, it felt like one of the front wheel's connection to the steering arms was loose, allowing the wheel to wobble back and forth. (I know this isn't the case because it'd be wobbling like crazy, esp. at 90 mph) [I'm in the country... empty highways nearly nobody around]
What could be the problem? Sway? Control arm bushings? (admitedly I don't know ^exactly^ what those two things are.) I know the alignment is messed up because when I turn, I can feel that the wheels aren’t lining up where they should be. (I know the inside wheel has to turn more than the outside, and it feels just like that). Everything just feels wrong.
It’s completely stock with 89k miles on it. (I’ve had it for 15k miles) Should I get new suspension soon? What does everyone recommend that I look for to replace and what extra should I do to my car (performance, I like turns ) Would most of this stuff be hard to do with a set of ramps + jackstands by myself or wtih a buddy? [we are both very mechanically inclined so I dont think it would be too hard] I havn't worked UNDER a car before
98 323 IS sport package.
Old 04-23-2004, 09:17 PM   #2 (permalink)
CiscoKid's Avatar
new suspension, check control arms, bushings and allignment
Old 04-23-2004, 11:45 PM   #3 (permalink)
WOT in Reverse
jllphan's Avatar
If it is as bad as you let on, if you can get under the car it should be self explanatory as to what is jacked up.
As far as replacements and upgrades, the harder you drive your car (i think we know in your case) the quicker all this s@#t will wear out. I plan on adding the Bilstein PSS9 coilover kit this summer and upgrading to stiffer sway bars. If you did this (and all of the hardware in between), it would undoubtedly allow you to go MUCH faster through all your favorite twisties!! :P
BTW, Autotechnica will certainly have something to say about this. If he doesn't see this thread you might PM him.
Old 04-23-2004, 11:48 PM   #4 (permalink)
Keep it Copacetic
///M Power's Avatar
Car: 1995 BMW M3
^^what he said
control arms/tie rods/your screwed haha
also cheq front ball bearings
Front Drive Shaft Loose On 325xi bmw_in_maryland 3-Series (E46, E90) 4 01-13-2005 06:44 AM
Wanted: Two Front E46 M3 Wheels BaLAnCe17 Classifieds Sell & Buy 0 12-23-2004 02:39 AM
Loose Front Wheels And Brake Rotors...help springer69 3-Series (E36) 1 11-23-2004 05:15 AM
Front wheels for E34 Saggis 5-Series (E12,E28, E34, E39, E60) 3 09-09-2004 01:37 PM
noise out of front and rear driver's wheels debbie M-Series (M1, M3, M5, M6) 5 11-22-2003 05:25 AM
