Puzzled by oil leak! - BMW Forum - BimmerWerkz.com
post #1 of 2 (permalink) Old 10-05-2010, 10:11 AM Thread Starter
Coachrob37 is on a distinguished road
I have a 1996 328I with 225000 miles on her. The problem is the "o" ring gasket (The Large 4'' one) for the screw cap to the oil filter housing bloats out and leaks when you run the car. The bloating is about 3/4 of an inch and is never in the same spot after re-adjusting.
This is the third "o" ring, the last one came from a BMW dealer. The housing isnt damaged and the "o" ring I even torqued down to the specified 25 nm (18ft,lbs) which it calls for.
The only other thing I have noticed is when I leave the car over night and pull the dipstick to check the oil the next morning you can actually hear the oil from inside the tube trickling back down in to the pan.
By the way the two small o rings that are on the oil filter cap assembly have never been replaced.
Could these o rings cause a possible pressure problem?
Any avenue I can pursue I would greatly appreciate, not to mention the faster I fix this the faster my wife drives the car again and stops complaining! Thank you in advance!
Rob
Coachrob37 is offline
post #2 of 2 (permalink) Old 10-10-2010, 10:54 PM
jmo69's Avatar
jmo69 is on a distinguished road
I guess I don't understand how a solid O-ring could bloat. I usually change oil once/year and the O-ring comes out the same way it went in. It fits into a groove in th cap and can't go anyplace once the cap is tightened. Is it possible that there are two on there, like someone didn't remove an old one before installing the new one? I've seen it happen on domestic spin on filters. Just my $0.02
Cosmos schwartz metalic Sparco strut brace factory X-brace 55w 6000k HID w/LED angel eyes smoked Lamin-X blacked out sidemarkers,tails and brakelights. DDM smoked corners and pedals. 35% tint all around, Prosport water temp and oil pressure gauges, Home Depot lip, M3 rear diffuser ASC-T delete.
jmo69 is offline
help.. i need to get out my cluster.. Puzzled. =( maciag 3-Series (E21, E30) 1 06-02-2007 08:41 AM
Oil Leak htp.bmw 3-Series (E21, E30) 6 09-07-2005 01:15 AM
Too Much Oil, Wrong Oil, Gas Leak? yammahamma 3-Series (E21, E30) 4 07-26-2005 07:20 PM
Oil Leak - anyone seen this Jmiller911 3-Series (E21, E30) 3 06-03-2004 11:27 AM
Oil leak... dubumb Bimmer Talk/Motorsports Talk 1 01-02-2004 02:44 PM
