Prop Shaft Coupling - BMW Forum - BimmerWerkz.com
Old 04-09-2006, 11:55 PM   #1 (permalink)
craigf is on a distinguished road
Unhappy Prop Shaft Coupling
My 318is has failed its warrant on the prop shaft coupling. They say its split...is this an easy job to repair or should it be done at the garage?
craigf is offline   Reply With Quote
Old 04-10-2006, 11:13 AM   #2 (permalink)
e36surge's Avatar
I've never had to deal with this but have you checked the Bentley?
I found the following link, it may help but it's for an e30 318is.
http://www.esatclear.ie/~bpurcell/31...html#propshaft
you can use this link to find the part. just enter your car's info.
http://www.realoem.com/bmw/select.do
hope this helps.
- Mario Andretti
1979 320is RiP
1994 318is Sold
1995 325is Sold
1995 530i Sold
2004 M3
Old 04-10-2006, 07:52 PM   #3 (permalink)
Thanks a lot. That realOEM is a great big help....
Cheers
Old 04-11-2006, 08:21 AM   #4 (permalink)
e36surge's Avatar
Don't forget to come back and tell us what happened.
Prop Shaft - The pleasure Danbot 3-Series (E21, E30) 3 01-26-2006 10:13 AM
Drive Shaft Problem... 97alpineM3 3-Series (E36) 9 12-02-2005 03:33 PM
Bad Cam/crank Shaft Sensors atifhalim 3-Series (E36) 4 07-14-2005 07:53 PM
Bent Drive Shaft Bimmer///Man3 3-Series (E36) 3 08-28-2004 01:17 AM
