projectors/angel eyes - BMW Forum - BimmerWerkz.com
Old 01-29-2004, 01:52 PM   #1 (permalink)
well_unless is an unknown quantity at this point
i recently installed new projector head lights, they were pre wired with harnesses to plug into the existing plugs so the install was fast and easy. The low beams work fine, the angel eyes i installed work great too, but the fog lights no longer go on and the high beams don't work either. Has anyone heard of this before. Would it be a short somewhere or maybe the pre-wiring is messed up? Please help...
projectors/angel eyes-img_0558.jpg
well_unless is offline   Reply With Quote
Old 01-29-2004, 03:55 PM   #2 (permalink)
Andrewsd1985's Avatar
Andrewsd1985 is an unknown quantity at this point
Send a message via AIM to Andrewsd1985
more than likely its the prewiring setup they gave you. I have the same problem with mine. Splice directly into the new connector and make sure all the plugs go onto the right pin.
PRESIDENT OF THE OVER 10 YEARS OLD AND UNDER 100K MILES CLUB
1993 325i 5spd
Benfer Performance Intake
M-tech Pedals and Shiftknob
Bavarian Auto Floor Mats
Wheelskin Steering Wheel Cover
Panasonic Head Unit
Euro Projector Lights w/ black Housing
Black Housing Clear Corners
Dinan Chip
MORE TO COME!!
<img src='http://plaza.ufl.edu/dunna/Pictures/banner.jpg' border='0' alt='user posted image' />
Andrewsd1985 is offline   Reply With Quote
Old 01-29-2004, 04:37 PM   #3 (permalink)
cardio is an unknown quantity at this point
Whoa, those things are awesome, whats the brand, and how much did they cost you? , sorry to change the subject, but they are awesome.
cardio is offline   Reply With Quote
Old 01-29-2004, 05:14 PM   #4 (permalink)
how do i determine whether or not each wire is going to the right place?
i bought the lights off of ebay, it didn't specify a brand, the lens says djouto. if thats the brand i don't know. they are beautiful, the angel eyes install can be a bitch but its worth it.
Old 01-29-2004, 05:15 PM   #5 (permalink)
oh yeah and they cost me only $235 with $45 shipping. Brand new and came in two days.
Old 01-29-2004, 06:41 PM   #6 (permalink)
350z
Car: 03 Nissan 350z Track
dude thats a great deal but my bet is it is the wiring harness specailly if you bought them from ebay! but thats just my 2 cents!
David
**BAKER POW REPORT**
Old 01-29-2004, 09:08 PM   #7 (permalink)
Defector
El Presidente's Avatar
Have you checked the bulbs? Its possible you didnt plug the right wires into the right pins, and its also possible that the highbeam ground disconnected from the lowbeam.
However, the fogs are designed to go out when the highs are on. This leads me to believe that somewhere along the line a switch or relay has died causing the two functions to cancel each other out, thus illuminating neither.
Old 01-29-2004, 09:24 PM   #8 (permalink)
i got the high beams to work, ground problem. but still no luck with the fog lights. if i turn the switch on, and touch the fog light's fuse with a tester (which would give it a ground), then the lights go on, but go of when i take the tester off. so it must be a ground problem. they worked fine before i installed the projectors so i don't know where to look. relay maybe?
Old 01-29-2004, 09:34 PM   #9 (permalink)
Defector
Indeed, most likely a relay problem.
Old 01-29-2004, 09:57 PM   #10 (permalink)
the fog lights don't have a relay do they? only fuses. are do they run off of the high or low beam light relays?
Old 01-29-2004, 11:27 PM   #11 (permalink)
Defector
i think its off the highs...ill get my wire diagram and check it out.
angel eyes morph 3-Series (E36) 8 03-28-2005 12:05 PM
daytime angel eyes k9coupe 5-Series (E12,E28, E34, E39, E60) 1 07-09-2004 05:26 PM
projectors/angel eyes well_unless 3-Series (E36) 0 01-29-2004 01:51 PM
