Problems Are Starting...please Help - BMW Forum - BimmerWerkz.com
Old 04-09-2005, 11:49 AM   #1 (permalink)
Bimma328 is an unknown quantity at this point
Hi all,
I have had my 96 328 for a bit over a year now and it has 85k on it. It has been doing the "check coolant level" thing that others have posted about since basically day 1, but thats just background. Anyway, recently its been making this whurrring noise from under the car. I believe it's wheel noise because it remains the same whether I'm in gear or not. Also, it gets higher in pitch as I speed up and seems to hit nat. frequencies around 30 and 50 mph (strong vibrations). Along with this, my AC/Heat unit is not working. It powers off by itself and will not turn back on (similar to what others describe). Could this be the unit itself or does it have something to do with the system (clogged ducts or something). Help on any of these issues would be greatly appreciated.
Thanks
Bimma328 is offline   Reply With Quote
Old 04-13-2005, 05:26 PM   #2 (permalink)
sirmj is an unknown quantity at this point
hi,
ur ac problem is because of a capacitor. i think it is 22ufd dont remember. u need to buy it online its not available at either radioshack or any other store.
regd ur coolant level, have u filled up ur coolant? how often does it seem to be leaking? is there white smoke comin out the exhaust?
regd the whurring noise it cud be either - water pump or low pressure on power steering hoses they tend to cause tht noise.
hth
sirmj
sirmj is offline   Reply With Quote
Old 04-13-2005, 06:54 PM   #3 (permalink)
Linds's Avatar
Linds has a reputation beyond reputeLinds has a reputation beyond reputeLinds has a reputation beyond reputeLinds has a reputation beyond reputeLinds has a reputation beyond reputeLinds has a reputation beyond reputeLinds has a reputation beyond reputeLinds has a reputation beyond reputeLinds has a reputation beyond reputeLinds has a reputation beyond reputeLinds has a reputation beyond repute
Send a message via AIM to Linds
BMW Fix
Coming soon...
Linds is offline   Reply With Quote
Old 04-13-2005, 08:08 PM   #4 (permalink)
Deloriant's Avatar
Deloriant is an unknown quantity at this point
Send a message via AIM to Deloriant
Ahhh, sorry I can't help you but I always drop by the 1996 328is threads! Woo!
<img src='http://i116.photobucket.com/albums/o17/M4yorThis/119575444991686.jpg'>
Deloriant is offline   Reply With Quote
BMW 318i 92Model E36 Starting Problems deanbelich 3-Series (E36) 7 09-21-2005 11:41 AM
Starting problems blackm 3-Series (E36) 6 09-14-2005 11:48 AM
problems starting car when cold... VLAD_325is 3-Series (E36) 8 09-12-2005 08:08 PM
Starting Problems BMWDriver86 3-Series (E21, E30) 15 02-09-2005 04:28 PM
Starting problems.... help? frigga 5-Series (E12,E28, E34, E39, E60) 1 05-26-2004 09:28 AM
