problems with car..AGAIN !!! - BMW Forum - BimmerWerkz.com
Old 05-29-2004, 07:34 AM   #1 (permalink)
mstar is an unknown quantity at this point
i have been told of some problems by my mechanic that my 328i se 1996 needs:
1. New brake fluid, any reccomendations? any standard of the shelf be good enough?
2. brake pads, normal OEM perfectly good? or shall i use a "branded" one you can get from the shops?
3. rear spring, are that really fragile? my car has only done 74K !! i will replace both rear springs (as only one is a bit dodgy), again BMW OEM ones fine? or shall i buy some branded ones you can get from garages etc
any idea's guys???
mstar is offline   Reply With Quote
Old 05-29-2004, 09:11 AM   #2 (permalink)
RallyE36 is an unknown quantity at this point
These are based for the Canadian model:
1. Get the BMW fluid (DOT #4). Like the anti-freeze, it's formulated for your car and not that much more
2. Brambo. Much less than BMW's and work great.
3. BMW's OEM. Otherwise you should replace them in pairs are the sprong rate will be different. I'm surprised you have to replace a spring with your low mileage. Hopefully your car didn't experience some "extreme conditions" in the past.
Good luck.
1996 E36 M44 318i 5sp LSD
Canadian Model
RallyE36 is offline   Reply With Quote
Old 05-29-2004, 12:47 PM   #3 (permalink)
Defector
El Presidente's Avatar
I have the sprinf issue checked by someone else.
As for brakes, Mintex makes good pads that are also supposed to be lower dust emiiting than factory. My wheels still have dust, but nothing like other bimmers.
Old 05-30-2004, 03:22 AM   #4 (permalink)
Super Moderator
dutchbmw's Avatar
What do you want with your car? For normally use get BMW OEM. Otherwise buy aftermarket parts. Search here at the forum for some good aftermarket brands.
BMW '96 M3 (SOLD)
June 2005 Car Of The Month!
Originally Posted by Torque
Old 06-02-2004, 06:43 AM   #5 (permalink)
ok, is it a good idea to replace all brake pads (frnt , rear) as it will cause a braking imbalance and tires to wear down quicker on the newer brake pads?
also, replacing both rear springs and need to replace the front too????
any good OEM makes for brake pads/springs?
Old 06-02-2004, 09:27 AM   #6 (permalink)
bimerok is an unknown quantity at this point
What you asked does not sound like poblem. sounds like reqular maintenance.
bimerok is offline   Reply With Quote
Old 06-02-2004, 04:04 PM   #7 (permalink)
Kevin325i's Avatar
I think the general rule with breaks and suspension, is if you're changing something make sure to do it to both sides. IE Front brakes- left and right. You don't always have to replace everything at each corner, but the most imbalance will be felt with old parts on one side and new parts on the other.
Simple terms- replacing just the front pads would be just fine. Or, replacing just the rear shocks would also be just fine.
Kevin
Kevin (President TBEA)
Old 06-02-2004, 04:59 PM   #8 (permalink)
CiscoKid's Avatar
i bought some rear brakes for $27, installed them myself... took about 45 mintues without any compressed air tools. they work fine.
maybe you should spend the extra money to get the dustless pads
Old 06-03-2004, 04:29 AM   #9 (permalink)
Super Moderator
dutchbmw's Avatar
Where can you get them? And are they good, I mean, no extra wear of the brake discs?
BMW '96 M3 (SOLD)
Molding Problems rxpert26 3-Series (E46, E90) 9 10-14-2005 07:00 AM
problems starting car when cold... VLAD_325is 3-Series (E36) 8 09-12-2005 08:08 PM
I test drive this Yesterday ! challe 3-Series (E36) 35 04-26-2004 11:17 PM
