Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
Old 06-28-2004, 05:14 PM   #1 (permalink)
Idle Member
Photos: 0
kraze0g is an unknown quantity at this point
Thumbs down
I have a 97 328i and i lowered my car about 4 weeks ago, i lowered it an inch. My problem I thought started when i put my rims on it about 3 days later and my steering wheel WOBBLES like all hell. It'll do it most times, maybe 1% of my driving is without it wobbling. It'll wobble all the time, no matter how slow or fast (although if i go about 65-70 it'll go away momentarily). Now i replaced the tires because I thought that was the problem, but it still does it. The place I took it to says it must be the struts because when he pushes up and down on one wheel, the opposite wheel in the front moves up and down with it. He says it'll be fixed with new struts. Does this sound right? I'd hate to buy struts and still have this problem.. would the struts solve the wobbling problem? Please give me your opinions/advice. Thanks
kraze0g is offline   Reply With Quote
Old 06-28-2004, 05:19 PM   #2 (permalink)
LOS
LOS's Avatar
Car: 97 540IA, 95 840CI
Photos: 1
Was any wheel alignment done?
Old 06-28-2004, 05:22 PM   #3 (permalink)
BlantonG13's Avatar
Photos: 0
BlantonG13 is an unknown quantity at this point
Send a message via AIM to BlantonG13
what did you do to lower the car? Coilovers? Lowering Springs? Its possible that you might have some worn out struts. Go for some Bilstiens or Konis...something that can stand the test of being lowered and aggressive driving.
1996 318i
5 Speed Manual
Alpine CDA-7895 Head Unit
12" Alpine Type-R, sealed box
Infinity Kappa 4" 2-way speakers(rear)
Infinity Kappa 5.25" component speakers(front)
Debaffled airbox, K&N filter
Tracked Mud on carpets
Shampooed and cleaned carpets
BlantonG13 is offline   Reply With Quote
Old 06-28-2004, 05:24 PM   #4 (permalink)
thekid's Avatar
Car: 95 M3
Photos: 0
how did you lower the car? Also what size wheels did you put on and what size tires?
Old 06-28-2004, 05:37 PM   #5 (permalink)
Idle Member
Photos: 0
I lowered my car with lowering springs and I have 18" rims on it
Old 06-28-2004, 05:45 PM   #6 (permalink)
jllphan's Avatar
Photos: 0
Have you checked to make sure the new ride height is consistent all the way around. IF it is not, this could likely be the cause of your wobbling....
Old 06-28-2004, 05:51 PM   #7 (permalink)
Idle Member
Photos: 0
should i just take it to meineke and have them look at it?
Old 06-28-2004, 07:07 PM   #8 (permalink)
Idle Member
Photos: 0
You guys suggest I take it to meineke and have them look at it or does it have to be the struts?
Old 06-28-2004, 07:08 PM   #9 (permalink)
97alpineM3's Avatar
Car: Blah
Photos: 0
97alpineM3 is a glorious beacon of light97alpineM3 is a glorious beacon of light97alpineM3 is a glorious beacon of light97alpineM3 is a glorious beacon of light97alpineM3 is a glorious beacon of light97alpineM3 is a glorious beacon of light
Your gonna get a small amount of negetive camber with 18s either way.... and since you lowered it... it just induces more camber on it... If you find that new shocks dont fix the problem.... or if an allinment doesnt fix it... I'd say get new camber plates.... that are adjustable... that might work.
1997 E36 M3 1990 E30 325i
Old 06-29-2004, 12:08 AM   #10 (permalink)
thekid's Avatar
Car: 95 M3
Photos: 0
what size tires?
Get the alignment checked first because that can be thrown off changing wheel and springs.
Old 06-29-2004, 02:48 AM   #11 (permalink)
6th Gear Member
Kevin325i's Avatar
Photos: 0
Did you put sport shocks on with the lowering springs? If you didn't then they're likely blown. Push down on the corner of the car, if it doesn't stop wobbling after one wiggle of the car your shocks are going, or are gone.
Kevin
Kevin (President TBEA)
Old 06-30-2004, 01:55 PM   #12 (permalink)
Photos: 0
PhunkDJti is an unknown quantity at this point
worn wheel bearings could be contributing to the wobble also.
the first (and cheapest) thing id do would be to get a wheel alignment. its always a good idea to get a wheel alignment after lowering a car anyways and it might just fix the problem too
PhunkDJti is offline   Reply With Quote
vB code is On
Problem With Springs - "i Think" Rich328 3-Series (E36) 12 03-30-2005 12:30 AM
Smg Problem On 330i johanfunsale 3-Series (E46, E90) 0 02-28-2005 08:33 AM
Difference: Coil Springs Vs. Coil-over Springs? funtoos 3-Series (E36) 3 02-27-2005 12:46 AM
Why Bother With Aftermarket Springs? jsomogyi 3-Series (E36) 2 02-03-2005 08:11 PM
Bilstein Sport Struts viali8 3-Series (E21, E30) 10 11-09-2004 06:07 PM
SEO by vBSEO 3.1.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
