Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
Old 07-12-2008, 08:43 PM   #1 (permalink)
Car: 1995 BMW 325I
Photos: 0
325IConvertible is on a distinguished road
Send a message via MSN to 325IConvertible
Problem with oil leaking from Oil Filter adapter and maybe more???????
I took my BMW up to a shop to have the codes ran for it stalling. We found out the throttle body needs to be cleaned out so we did that.
I also had them look to find this oil leak im starting to have as of recently.
3 weeks ago I noticed the car was leaking OIL in large amounts so I had them look at that today as well.
It seems the oil is coming from the oil filter adapter housing or as they call it aka the engine oil filter housing !!!!!!! The mechanic said its either an O ring or a Gasket that needs to be replaced or a cracked housing.
Now for the problem or what may be a problem..... this is where I need expertise in one of yall.
The guy showed me on his computer written in bold wording ..... below where it talks about replacing the Engine oil filter housing it says
on 325I ........... R/R CrankShaft........meaning remove and replace cranksahft
is this true ? when replacing the oil filter housing or replacing the gasket/ O ring does this have to be done and why if so ?
ANY HELP WOULD BE GREATLY APPRECIATED
1995 325I Convertible
2002 Corvette Z06
1969 SS 396 Camaro
325IConvertible is offline   Reply With Quote
Old 07-12-2008, 09:00 PM   #2 (permalink)
Photos: 0
witeshark is just really nicewiteshark is just really nicewiteshark is just really nicewiteshark is just really nice
How many miles on the engine? Has any serious work been done on it before? That makes no sense. A bad oil filter housing shouldn't have any need for a new crankshaft. That only needs to be done for new main bearings. That amounts to about a total engine rebuild and usually the cylinder head needs that kind of work first.
Old 07-12-2008, 10:15 PM   #3 (permalink)
johnnybayonne's Avatar
Car: 1997 BMW 328i
Photos: 0
johnnybayonne has a spectacular aura aboutjohnnybayonne has a spectacular aura about
That makes absolutely no sense, I just looked in my Bentley & although it did not show a R & R for a oil filter housing...... They do show a R & R for the oil pump which includes removal of the Oil filter housing filter housing & timing chain cover & timing chain to get to the oil pump.......No mention what so ever of the crank shaft............. I think this guy is trying to give you the SHAFT.......Also found this thread @ bimmerfest about adding a oil cooling kit to their housing, and changing over to a euro filter housing & guess what, no talk about replacing their crankshaft......find another mechanic......
johnny,
go to post #7, then click on thumbnail......
Anyone install the Euro oil cooler on S52? - bimmerfest - BMW Forums
RealOEM.COM Part Category Selection
1997 Cosmos Black 328i w/optional Sports Package
http://www.cardomain.com/ride/3129109
johnnybayonne is offline   Reply With Quote
Old 07-12-2008, 10:16 PM   #4 (permalink)
Noob
SHAHAB323IS's Avatar
Car: 2008 s2000
Photos: 0
SHAHAB323IS is a glorious beacon of lightSHAHAB323IS is a glorious beacon of lightSHAHAB323IS is a glorious beacon of lightSHAHAB323IS is a glorious beacon of lightSHAHAB323IS is a glorious beacon of lightSHAHAB323IS is a glorious beacon of light
You don't have to remove the crankshaft. There's two o-rings one big one and one little one that come with new oem oil filters. These should technically be replaced when you change the filter but most people don't do this, including myself when I had my e36. I'd check the housing for any cracks first, it's a couple of screws and an oil line to replace it, but hopefully a new set of o-rings and or gasket seals will do the trick. You can use this picture for reference
BMWCCA member id #380000
SCCA member #400289
Old 07-13-2008, 01:25 AM   #5 (permalink)
Car: 1995 BMW 325I
Photos: 0
Thank You all Very much for replying I am in need for help with this.
The guy told me he didnt want to steer me in any wrong directions with this crankshaft thing. He told me it probably would take about 2 hours Max to replace the housing and probably the same if its only the o rings.
He told me to hold off look into some info about this and get back with him on monday...... because the people who would know 100% about this are not in reach right now and he wasnt going to lay anything in stone for what his computer was saying.
SHAHAB323I thanks for posting up about this if you can get those photos up some how that would be great.
Johnny thanks for the link I will check it out.
whiteshark this car does have high miles on it and no I have not knock on wood had any BIG problems out of it..... biggest was radiator exploding at the water neck 3 months ago which got me into replacing 99% of the cooling system lol.
2002 Corvette Z06
1969 SS 396 Camaro
Old 07-13-2008, 07:31 AM   #6 (permalink)
Noob
Car: 2008 s2000
Photos: 0
exploding radiator neck is common so not to worry, the picture is up, and it's the same from what johny posted (we posted at the same time). replacing the o-rings takes two seconds
SCCA member #400289
Old 07-13-2008, 11:09 AM   #7 (permalink)
darkhorse737's Avatar
Car: 88 super ETA, 99 C43 AMG, 89 300SEL
Photos: 0
Send a message via Yahoo to darkhorse737 Send a message via Skype™ to darkhorse737
Lightbulb
check carefully and think back.... if the oil started leaking soon after your last oil filter change, could just be an oil filter screwed in the wrong way, unless what you have is the element type, of course. Then there's the base gaskets... they're known to leak also.
I would clean the oil leaks with brake cleaner; then start the car so u can visually see where the leaks actually comes from.
on the average, the job to remove and replace housing &/or filter adapter involves 2.7hrs labor(multiply that by your fave shops hourly rate)
ay sino caddi ububblaem? Heaven won't take me; and Hell just knows I'll take over...!
Old 07-13-2008, 01:39 PM   #8 (permalink)
Car: 1995 BMW 325I
Photos: 0
Yall have all be GREAT Help !!!!!!!!!!! Ty so very much im looking on pelican so I can do this myself but can seem to find it. Anyone care to give it a try and post the link lol
Thanks again I will keep yall posted
2002 Corvette Z06
1969 SS 396 Camaro
Old 07-13-2008, 02:15 PM   #9 (permalink)
Photos: 0
Talking
You're in luck...just 6 bolts to remove the housing.
fairly easy job, and it's easily accessible
have fun
problem-oil-leaking-oil-filter-adapter-oil.jpg  problem-oil-leaking-oil-filter-adapter-oil2.jpg
Old 07-13-2008, 04:26 PM   #10 (permalink)
my car is red
94BMW325i's Avatar
Car: 94 325i, 97 golf, 84 scirocco
Photos: 0
My car used to have a really bad leak from the oil filter housing, till I replaced it.
Old 07-16-2008, 04:35 AM   #11 (permalink)
Keep it Copacetic
///M Power's Avatar
Car: 1995 BMW M3
Photos: 0
325Vert, do you know where the oil filter housing is in your engine bay. If you open up the hood you will see it immediately. It is located at the front of your engine in a silver cylinder housing with a lid screwed down on top of it with a large bolt. Front of engine slightly drivers side when look at the engine dead on. Do you see any leaks or oil residue on it? It's probably just a bad seal/ring. Whenever you replace the oil filter you're supposed to put new o rings on or at least transfer the old ones over. Very simple to do, just need a large wrench to go over that large bolt on the top of the housing.
Old 07-16-2008, 01:42 PM   #12 (permalink)
Administrator
Furious's Avatar
Photos: 0
absolutely not needed. you dont have to re&re the crankshaft to do it. i mean you can but no need to. a good mechanic would know how to get around that, if your only doing. chances are its gonna be the gasket.
R.I.P Steve aka fast 6
Old 07-16-2008, 11:54 PM   #13 (permalink)
Car: 1995 BMW 325I
Photos: 0
Well once again TY to all of you who threw in some help with your ideas and wonderful info !!!!!!!!!
It's Fixed it was the Gasket on the back of the housing. Well what left of the gasket from before lets put it that way lol
Every time I tear into this car im amazed by the technology from 1995 to where is it today. shakes head oh well Thank again maybe now I can get to this stalling problem. I hope its a fuel filter !!!! just gotta find it first lol
Thanks again for the help !!!!
2002 Corvette Z06
1969 SS 396 Camaro
vB code is On
oil leaking from a few places... yammahamma 3-Series (E21, E30) 31 11-02-2006 11:28 PM
Oil Leaking Under Intake kcosh 5-Series (E12,E28, E34, E39, E60) 5 05-05-2005 09:27 PM
Oil Leaking?? ayyado 3-Series (E36) 5 11-21-2004 06:56 AM
Oil leaking from under carriage! Delmarco 3-Series (E36) 7 09-09-2004 08:16 PM
leaking oil? IvanB 3-Series (E36) 2 05-28-2004 07:02 PM
SEO by vBSEO 3.1.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
