Problem With The Lock On The Trunk - BMW Forum - BimmerWerkz.com
Old 12-09-2004, 10:43 PM   #1 (permalink)
uclabruins1996 is an unknown quantity at this point
1996 328I
Greetings,
I have another problem with my vehicle. It is difficult to manually lock and unlock the trunk lock. I insert the key into the locking mechanism, but I cant turn it right or left with normal force. I have to use a lot of force (to point of almost breaking the key) to turn the lock in the lock and open position.
I have tried spraying WD-40 into the lock hole, but it still doesnt work.
What should I do to get this lock to operate smoothly.
Thanks
<a href='http://img96.exs.cx/my.php?loc=img96&image=Black.jpg' target='_blank'><img src='http://img96.exs.cx/img96/426/Black.th.jpg' border='0' alt='user posted image' /></a>
<a href='http://img96.exs.cx/my.php?loc=img96&image=Blackcolor.jpg' target='_blank'><img src='http://img96.exs.cx/img96/7590/Blackcolor.th.jpg' border='0' alt='user posted image' /></a>
uclabruins1996 is offline   Reply With Quote
Old 12-10-2004, 07:38 AM   #2 (permalink)
ex owner/admin
Furious's Avatar
well, how often do you use the trunk lock?
........better yet how often did you used to use the lock? im sure its probably starting to seize up, wd40 it again and let it sit in a warmer enviroment (if its cold where you live park it in the garage) see if it cant seep in and get the lock to work a little smoother.
Old 12-10-2004, 08:07 AM   #3 (permalink)
///Matt's Avatar
Taking so much force to turn suggests that one of the rods is bent or jammed. Try to peel off the inside trim and inspect the mechanism itself.....and good to see another St. Louisan
Old 12-17-2004, 01:16 PM   #4 (permalink)
[snapback]247232[/snapback]
I will try that.....
Likewise...great to see another fellow St Lousian
Old 12-17-2004, 01:29 PM   #5 (permalink)
JAX
JAX is an unknown quantity at this point
Send a message via MSN to JAX
/// Matt
E24 M6
E30 325ic
E39 540i
E46 M3 - RIP
E46 330i
E46 330ci
E65 745Li - FOR SALE
Damn man ..... get a life .... U make me gelous man ... so many damn bimmers... where do you live ? Got inssurance ?
I also think that something got jammed inside , better open , take it out and see it with your own eyes.
Try the key when it is outside and then you can se exactly whwre the problem is.
--== 316i Cupe / 325TDS Engine ==-- <br> --------------183 HP----------- </br>-- == JAX the RiPPeR == --
JAX is offline   Reply With Quote
Trunk Problem rakeshp 5-Series (E12,E28, E34, E39, E60) 4 07-07-2005 12:33 PM
2000 E39 Central Lock Problem rsacho 5-Series (E12,E28, E34, E39, E60) 1 04-24-2005 02:01 PM
Trunk Lock Not Opening With Key On 96 328 Conv. MunirShaikh 3-Series (E36) 5 04-23-2005 09:17 PM
Trunk Lock Failure couvebmwgirl 3-Series (E36) 13 01-13-2005 12:29 PM
Power Window And Door Lock Problem...96 750il moabxj01 1,6,7,8 - Series and Mini Cooper 1 11-16-2004 03:30 PM
