Problem with E36 Vert Roof leakage !!!!! - BMW Forum - BimmerWerkz.com
Old 07-05-2007, 07:02 PM   #1 (permalink)
Car: 1995 BMW 325I
325IConvertible is on a distinguished road
Send a message via MSN to 325IConvertible
I live in Texas and for some reason for the past 2 months it wont stop raining as most of you have probably heard from the New's. Flooding everywhere I noticed as of the last few weeks that the Top is leaking around where the window and vert top meet. Here are a few pictures I took earlier today after work.... sorry for the bad quality if you cant see them to good its so humid and wet here that the camera even fogs the lense.
How can this be fixed ? Does anyone on here have a sloution ???? I know most of you dont have a Vert but im noticing with the BMW crowd you guys usually have the right answers when it comes to these babies !!!!!!!!!!
Thanks for any help that is given David !
here is a picture with it closed and with the water leaking in.
here is with it open with a little bit of water showing where its collecting
here it is when it is dry and closed
1995 325I Convertible
2002 Corvette Z06
1969 SS 396 Camaro
325IConvertible is offline   Reply With Quote
Old 07-08-2007, 05:11 PM   #2 (permalink)
Science Roolz!
Car: 2011 Mazda2, 1990 Miata
you're going to have to change your seals, it's a routine maintenance item, especially on verts, but most people ignore it, over time the rubber seals become brittle and crack, which causes the leaking, I work at a dealership and pretty much every e36 customer car leaks when I take it through the car wash, z3's as well, I'd suggest going to the dealership and having them do it, or if you feel like changing it yourself you can take it there and have a parts guy look at your car so you can determine which seal needs to be replaced
looks like number 3 in that picture might be the culprit, the cowl gasket, i'm not sure, you can study that diagram if you want, check out realoem.com if it's not in that picture
here's a link to that section
RealOEM.COM * BMW E36 325i FOLDING TOP MOUNTING PARTS
p.s. I like the SS in the background =]
2011 Mazda2
1990 Mazda Miata
Old 07-16-2007, 10:19 PM   #3 (permalink)
Car: 1995 BMW 325I
Thanks for the info !
2002 Corvette Z06
1969 SS 396 Camaro
Smg Problem On 330i johanfunsale 3-Series (E46, E90) 0 02-28-2005 07:33 AM
Bmw 325 Iac Problem With The Roof ThunderSS 3-Series (E36) 1 10-08-2004 02:29 AM
Collant Leakage problem RedBeemer95 3-Series (E36) 13 08-03-2004 12:14 PM
Problem with the Coolant Leak RedBeemer95 3-Series (E36) 3 07-23-2004 02:53 PM
E30 electric convertible roof will not lock ijahn2000 3-Series (E21, E30) 0 05-04-2004 08:25 AM
