Problem Dam Dam.. - BMW Forum - BimmerWerkz.com
Old 01-17-2005, 12:59 PM   #1 (permalink)
gt325i is an unknown quantity at this point
Angry
ghead HI HOW ARE YOYU BIMMER BOYS DOING.I AM NEW TO THIS FORUM SO ILL STAR I REALY NEED HELP WITH THIS PROBLEM WHEN I PUT MY FOOT TO ACCELERATE THE CAR STUTTERS THEN TAKES OFF AND WHEN I TURN THE CAR ON THE ENGINE REVS AND THE EXHUST STARTS TO SMELL VERY RICH WHAT COULD BE THE PROBLEM..SOMEONE PLEASE HELP ME ...
gt325i is offline   Reply With Quote
Old 01-17-2005, 01:14 PM   #2 (permalink)
93 325i's Avatar
This seems to be a popular problem recently..Check the Mass Air Flow meter, check for vaccum leaks, O2 sensor....Look down the board as well and you'll see similar problems being discussed..
My car actually "revs" up on start up to (more than a normal start should). With mine im certain it's an O2 sensor starting to go. My MPG is down as well..
Complete mod list and pics:
My 1993 325i
Old 01-17-2005, 01:31 PM   #3 (permalink)
Unhappy
[snapback]273335[/snapback]
HI THANKS SO MUCH BUT AM NEW TO THIS STUFF WHERE COULD I FIND THE MASS AIR FLOW METER AND O2 SENSOR AND WHAT IS MPG..SEEEEE I TOLD U AM NEW TO ALL THIS SHIT.LOL THANKS
Old 01-17-2005, 02:08 PM   #4 (permalink)
Rooz's Avatar
Car: 2003 M5
mass air flow sensor, besides your air intake under the hood, close to where you change your air filter.
02 sensor, I't under the car, right before your catalyst converters
MPG = Miles Per Galon
VIEW MOD LIST & PICS
Originally Posted by Gregg
Rooz is offline   Reply With Quote
Old 01-17-2005, 06:09 PM   #5 (permalink)
drz
master of his domain
drz's Avatar
Car: zhp
Originally posted by gt325i+Jan 17 2005, 02:31 PM--><div class='quotetop'>QUOTE(gt325i @ Jan 17 2005, 02:31 PM)</div><div class='quotemain'><!--QuoteBegin-93 325i@Jan 17 2005, 01:14 PM
[snapback]273357[/snapback]
[/b][/quote]
Sorry I cannot be of help but there is something you need to know about the forum: when you type in all-caps, you are SCREAMING AT US!!! You are new, so that's ok, but it can really get annoying. I hope you get your car fixed. I have repairs pending on my BMW as well. Good luck.
Turkey Fleet Bond Holder
Old 01-17-2005, 06:58 PM   #6 (permalink)
Originally posted by drz328i+Jan 17 2005, 06:09 PM--><div class='quotetop'>QUOTE(drz328i @ Jan 17 2005, 06:09 PM)</div><div class='quotemain'>
[snapback]273579[/snapback]
[/b][/quote]
thank u guys so much.ok where can i get a new 02 sensor
Old 01-17-2005, 07:18 PM   #7 (permalink)
drz
drz's Avatar
Car: zhp
You can get it from www.bavauto.com. Of course you can always get one at the stealership. Bavauto has just about anything you could need for your car. If you are uncertain, you can always give them a call and talk to someone who knows. Don't rush to get an O2 sensor. If one is failing, very likely the 'check engine' light would illuminate. Also, just a few days ago we were having a discussion about how many O2 sensors an E36 has -- I don't know that we settled it, but it is anywhere from 1 to 4 sensors. There is a lot of info on this forum -- run a search or use Google (which very likely direct you to a board on this site). Good luck.
Old 01-18-2005, 08:04 AM   #8 (permalink)
93 325i's Avatar
BimmerWorld.com has the cheapest OEM O2 Sensor. My car is a 93 (has only one O2 sensor) and has 130K. My gas consumption is really high (just over 18 miles per gallon) so I know it's good preventative maint. anyway.
An O2 sensor will show signs it is going before the check engine light comes on. Poor performnace (the hesitation, stuttering), eratic idle, strong smelling exhaust.. If you have a pre 1996 E36 with higher miles then I think it's worth a shot at replacing the O2 sensor.
My 1993 325i
Old 01-18-2005, 08:46 AM   #9 (permalink)
ChahalzBMR is an unknown quantity at this point
I had the exact same problem as you last week. All I need to do was a spark plug change (all 6) and an oil change. It runs great now! Go with NGK plugs!!!!
<img src='http://img43.exs.cx/img43/275/Resize.jpg' border='0' alt='user posted image' />
Body: 318i 4 door
Mods: M50 engine, Jim C chip, light-weight flywheel, dual cat-back custom exhaust, 3:15 lsd, euro headlights w/angel eyes, 5300K HID, smoked corner lights, FK Motorsports foglights (crystal clear), ABS plastic upper eyebrow, clear side markers, M3 powered side mirrors w/LED, blacked out grill, M3 lighted shift knob, 17&quot; ROH Furry wheels w/Kumho tires, Brembo cross drilled rotors and Hawk performance brake pads all around, PSS9 Bilstein and H&amp;R coil over kit, front strut bar and Alpine alarm.
ChahalzBMR is offline   Reply With Quote
Old 01-18-2005, 11:00 AM   #10 (permalink)
Jamez's Avatar
Jamez is an unknown quantity at this point
Send a message via AIM to Jamez
Ive gotten the CHECK ENGINE red light few days ago the whole time I was driving that one night. But the following days never saw the light again... you thinK I should still change my o2 sensors? Also my MPG is really low like 15 mpg sometimes 14 mpg but I think thats normal since I rev alot and exceed 3,000 rpm even on street roads.
BMW e36 325is
Current MODS:Turner Motorsport Conforti Performance Chip, CAI, Lowered/Eibach, Ace Zeus 18's, Bilstein shocks, AUDIO: Kenwood Headunit, Kenwood Equalizer, Infinity speakers, two MTX amps, JL 12&quot; subwoofer, 5% rear tint and more to come....
Soon MODSListed by soonest priority first) Euro Ellipsoid Headlights w/DDE Lighting &amp; HIDS/Xeons, Smoked Euro Taillights, Rieger M3 Front Bumper, Rieger M3 Rear Bumper.
<a href='http://www.bmw-forums.com/forum/index.php?showtopic=26973' target='_blank'>My Car & I PICTURES</a>
Purchased Date: 10-23-04 | Tickets: 6|
<img src='http://img112.exs.cx/img112/2113/mybmw0vg.jpg' border='0' alt='user posted image' />
<div class='quotetop'>QUOTE</div><div class='quotemain'>&quot;Live Life Well, its the Ultimate Revenge&quot;</div>
Jamez is offline   Reply With Quote
Old 01-18-2005, 07:41 PM   #11 (permalink)
[snapback]273951[/snapback]
Hi thank u so much for the information....
Old 01-18-2005, 08:15 PM   #12 (permalink)
[snapback]274032[/snapback]
Hi well I think u should wait and see if your check engine light comes back on.
Old 01-18-2005, 08:18 PM   #13 (permalink)
Old 01-18-2005, 08:20 PM   #14 (permalink)
Old 02-24-2005, 07:32 AM   #15 (permalink)
oe_tuning is an unknown quantity at this point
How much would an O2 sensor cost?
oe_tuning is offline   Reply With Quote
528i Alarm Problem Xero 5-Series (E12,E28, E34, E39, E60) 5 01-03-2011 01:16 PM
Smg Problem On 330i johanfunsale 3-Series (E46, E90) 0 02-28-2005 07:33 AM
Alpine 9835 Fm Tuner Problem ultraviolet353 Audio and Electronics 7 09-22-2004 11:09 PM
