PROBLEM: Car won't start. Help. - BMW Forum - BimmerWerkz.com
Old 04-02-2009, 09:35 PM   #1 (permalink)
BombSquad91's Avatar
Car: 1994 325is 5spd
BombSquad91 is on a distinguished road
My car won't start. I parked my car at school, came out an hour later, and it won't start. Battery is fine. I turn the key to start and nothing happens. I turn the key to on, the cluster lights come on, I turn the key to start and nothing happens. It's as if the ignition wires were cut, which they weren't. So I push started it and it drove fine. What do I do? No fuses are blown. Where do I start troubleshooting?
My BMW misses Hondy.
My BMW never sees a shop.
My BMW grew up on Franny Lew.
BombSquad91 is offline   Reply With Quote
Old 04-02-2009, 09:44 PM   #2 (permalink)
jmo69's Avatar
Car: 1998 328is 2003 325xi
jmo69 is on a distinguished road
Neutral safety switch, or whatever it's called on the clutch pedal, so it won't start in gear. From there to the wires on the starter beginning with the battery connections. Clutch switch would be my guess, but that's only a guess.
Cosmos schwartz metalic Sparco strut brace factory X-brace 55w 6000k HID w/LED angel eyes smoked Lamin-X blacked out sidemarkers,tails and brakelights. DDM smoked corners and pedals. 35% tint all around, Prosport water temp and oil pressure gauges, Home Depot lip, M3 rear diffuser ASC-T delete.
jmo69 is offline   Reply With Quote
Old 04-02-2009, 09:56 PM   #3 (permalink)
I don't have a neutral safety switch. I was always able to start the car without pressing the clutch. I'm going out there in a few minutes to check the wires. Thanks for the suggestion.
Old 04-02-2009, 10:07 PM   #4 (permalink)
jmo69's Avatar
I'm guessing the switch is normally open just the oposite of your refrigerator light switch. If you connect the wires together it will complete the circuit to allow starting.
Old 04-02-2009, 10:08 PM   #5 (permalink)
I'll check that out too. I'll start there actually.
Old 04-03-2009, 12:04 AM   #6 (permalink)
Sodium Chloride
saltshaker185's Avatar
Car: 95 M3
try jumping it... i think your battery is dead. but you dont think it is.
Old 04-03-2009, 12:05 AM   #7 (permalink)
Battery isn't dead. All electrics work fine and at full power.
Old 04-04-2009, 06:26 PM   #8 (permalink)
Car: 95 318is -- love the car
talisman318is is on a distinguished road
Starter Going Bad
If you experience these symptoms, need to start thinking about the un-fun task of replacing the starter. Starts fine, you run it -- then turn it off while hot and when you come back shortly afterwards it won't start. If you let it cool down for a couple of hours and then it will start -- starter replacement is in order. I thought it was everything else until a starter guy told me what those symptoms meant. Replacing the starter on your car is no easy task unless you've been through it before. I thought it wouldn't be too different from anything I'd ever seen before. Wrong. Wrong. Wrong. Had to remove the intake manifold, fuel rail assembly, wiring harness, and after going at it that way I think it may have been a better idea to pull the transmission to replace the starter. But either way, it takes a lot to get to those two bolts to replace that starter. Hope you come up with another fix. Good luck.
talisman318is is offline   Reply With Quote
Old 04-04-2009, 06:31 PM   #9 (permalink)
The shop tested my starter and it works. There's just no power getting to it. I'm gonna wire up a push button start. By the way, replacing the starter isn't that hard. Do you have an automatic? It's easy on a manual. You have to go from the bottom. Clamp and remove the fuel filter and you have good access to the starter.
need help with hard start problem hbbodley 3-Series (E46, E90) 5 02-19-2009 02:59 AM
Start problem migut 3-Series (E21, E30) 6 06-08-2007 05:19 PM
Car not switching on, self works but doesnt start the car, plz help guy... djfactor 5-Series (E12,E28, E34, E39, E60) 1 11-10-2006 09:41 AM
Cold Start Problem arstaff 5-Series (E12,E28, E34, E39, E60) 2 09-27-2004 07:26 PM
No Start problem slyhog-22056 1,6,7,8 - Series and Mini Cooper 1 07-05-2004 02:23 PM
