power window problem - BMW Forum - BimmerWerkz.com
post #1 of 4 (permalink) Old 12-20-2012, 08:03 PM Thread Starter
jake21 is on a distinguished road
I am in need of a wiring diagram for 1998 318i power windows. Does anyone know where I can get it? Jake
jake21 is offline
post #2 of 4 (permalink) Old 12-21-2012, 07:12 PM
Bills86e is on a distinguished road
I bought a FSM off eBay.
What problem are you haveing?
you could go to: RealOEM.com Online BMW Parts Catalog type in your VIN or last seven digits, I think (been awhile)
and look at the microfishe if its mechanical. One thing that can be causing is the sliders. If the lubricant in the rails has dried out and become too gummy. It can make the window think it has hit a stop.
Adding extra lithium grease in the slider rails has helped many different issues with the windows.
Also, you might need to order some new sliders. The window glass has two aluminum channels glued/bolted on.
The regulator has two arms with swivel points that snap in to plastic sliders.
With the window mostly all the way down, you can see the arms through the openings.
The lubricant goes where the little rubber sliders are, in the rail.
Once your interior panel is removed, you could unplug the wire connector, test with your olm meter and see if ya get 12v when you hit the up/dn button to determine if its incoming electrical, like fuse or button. If you do, then replace the window motor.
Please elaborate.
Bills86e
Bills86e is offline
post #3 of 4 (permalink) Old 12-21-2012, 07:49 PM Thread Starter
No power at the door and no power at the window switches. The breaker checks ok but ther is no power there. Both fuses are good. also the sunroof does not work. I check some of the threads and read about the comfort relay. Took the panel off under the stearing post and could only find the hi beam relay and crash relay. Not sure if their is a comfort relay in this year. If so it is above the stearing post. Any ideas? Jake
jake21 is offline
post #4 of 4 (permalink) Old 12-22-2012, 08:43 AM
Now I know why you will need all the wire diagrams.
Suggest you get this:
BMW 328i 323i 318i M3 E36 Shop Manual Service Repair Bentley Book 1996 1997 1998 | eBay
Money well spent
Bills86e
Bills86e is offline
1996 328i Power Window and Power Locks Problem stv 3-Series (E36) 14 07-27-2008 10:44 AM
Power Window Problem 123NotIt 3-Series (E36) 4 12-02-2004 03:02 PM
power window problem Stunnd65 3-Series (E36) 7 07-02-2004 10:17 PM
Power window-problem Scampi 3-Series (E36) 25 06-24-2004 11:41 PM
Power window problem. Boost 3-Series (E36) 5 06-23-2004 03:15 PM
