First thing i would check is behind the glove box, that is the window control unit make sure you have a solid connection, might of somehow got knocked loose while you were working with the wires or the connection is worn out. Most likely it is not a mechanical problem unless you did something in the door panels. If you would have to replace it I believe its around 150, but id look around in some junkyards, hope this helps you out some!
