Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
» Sponsor Links
»Garage Storage and Cabinets
Old 11-24-2004, 08:18 PM   #1 (permalink)
Idle Member
123NotIt's Avatar
Photos: 0
123NotIt is an unknown quantity at this point
About a month ago, my passenger side power window started getting really stubborn. I would have to press the switch quickly a few times in order for it to respond. But now the window has stopped working completely.
Here's what I did to troubleshoot:
First I removed the front door panel, then removed the front power window motor. I tested the connector with a multi-meter and when I hit the switch, the meter read +12.2v or -12.2v. This told me the motor was in fact getting voltage and I could rule out the switch or the circuit being bad. The next step was to test the motor itself to see why it wasn't spinning even though it was getting voltage.
To test the motor, I removed the rear passenger door panel and the rear power window motor and swapped it for the motor from the front window. It worked! - But why did the front power window motor work fine when I hooked it up in the rear door but it didn't work in the front door, and at both places the multimeter read the necessary 12v?
Please help me. Any ideas would be greatly appreciated.
<img src='http://sonny.ramsay.us/m3_footer.jpg' border='0' alt='user posted image' />
123NotIt is offline   Reply With Quote
Old 11-24-2004, 08:30 PM   #2 (permalink)
BMWLotAttendant's Avatar
Photos: 0
BMWLotAttendant is an unknown quantity at this point
Send a message via AIM to BMWLotAttendant Send a message via MSN to BMWLotAttendant
Sounds like you need a new window regulator.
BMWLotAttendant is offline   Reply With Quote
Old 11-25-2004, 04:03 PM   #3 (permalink)
Idle Member
123NotIt's Avatar
Photos: 0
The window regulator seems to be okay because I can move the window up and down with the motor detached. used The problem is - with the motor detached from the regulator completely and just hooked up to power, so there is not mechanical restriction - it won't spin. But if I hook it up in the back it will spin. When I test the electrical leads with a multimeter, both the front and the back are getting 12v power. Why would the motor spin on one but not the other when they are both getting the same power. ghead
Old 11-25-2004, 09:51 PM   #4 (permalink)
94 325is's Avatar
Photos: 0
94 325is is an unknown quantity at this point
Send a message via AIM to 94 325is
i dont know how many prongs the plug has but you can see if the rear plug is getting power to same prongs as the front. it could also be a ground problem if it grounded through the plug.
not many ideas other than that .. used
94 325is is offline   Reply With Quote
Old 12-02-2004, 03:02 PM   #5 (permalink)
Idle Member
123NotIt's Avatar
Photos: 0
The plug has 2 prongs. To test the ground problem I used the ohm meter to test the resistance between the prongs and the car's frame. I noticed something strange though when I had the positive prong hooked up and I pressed the switch. The resistance on the ohm meter went to infinity. This only happened in the front, not the back. I remember from physics class that V(voltage) = I(current) x R(resistance). So, if the voltage was increasing when I hit the switch and the resistance went to infinity, this meant that there was little or no current. When I thought about this more, I realized that maybe I should check out the switches more (maybe they are dirty or something and so not passing any current). Sure enough, it was the switches! I was thrown off before when I tested the switches and I saw the correct voltage change, I needed to see that they weren't passing any current to see the problem.
It all works now!!! Thanks to Blondestar - 'ohh...you wouldn't believe it...the switch is actually bad'
Thanks for the help though BMWLotAttendant and 94 325is!
vB code is On
M3 E36 Power Windows Problem vijay M-Series (M3, M5, M6) 6 12-17-2004 03:09 AM
Power Window Problem ghettozn 3-Series (E36) 11 09-05-2004 02:25 PM
Power Window Trouble... HoFF 3-Series (E21, E30) 8 09-01-2004 05:58 PM
Window problem on a 1997 328iS bhobmw 3-Series (E36) 2 08-19-2004 11:34 AM
power window problem 97328is 3-Series (E36) 4 04-12-2004 11:56 PM
SEO by vBSEO 3.1.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
