Power Window Problem - BMW Forum - BimmerWerkz.com
Old 09-01-2004, 03:07 PM   #1 (permalink)
ghettozn is an unknown quantity at this point
Send a message via AIM to ghettozn
Today my windows were able to go down, then i went to school and tryed to make them go all the way up, and it would not fully go up. I tried and tried but eventually the window was just stuck in the middle(could not go either way). After school my freinds helped to pull the window up, while i pushed the power window button. We thought it did not work but finanly after i closed my doors to give up, on this hopeless mission, the windows came up! I want to know the cause of this and how to fix it. Also, since it is up should i risk ever opening the window again before it is fixed?
Thanks
ghettozn is offline   Reply With Quote
Old 09-01-2004, 05:13 PM   #2 (permalink)
gah* tested my window again, apparently sometimes it needs help up(someone sllightly pulling on it) or sometimes it does go up on its own anybody know the fix?
Old 09-02-2004, 04:52 PM   #3 (permalink)
Fudge, my windows dont move up or down anymore, it just a clicking sound next to the motor. ANybody know how to remove the motor? Or tell me what to do pleasE!!! Aim me @ ghettozn if you want to help also !!
Old 09-02-2004, 04:58 PM   #4 (permalink)
chungaa1 is an unknown quantity at this point
i don't think it's your motor.. it probably fell off the track getting misaligned somehow... just open the panel (easy), see what u got... and go from there....
should take 10 minutes at the most....
btw, u may want to order some new grommets, those things break easily if not careful when realigning the panel back
chungaa1 is offline   Reply With Quote
Old 09-02-2004, 06:11 PM   #5 (permalink)
Defector
El Presidente's Avatar
You say windows though...
Do you mean all of them or just one? If its just one, I second the track alignment. Worst case the the entire control arm broke, but that generally results in the window falling and not being ble to hold itself up.
Old 09-03-2004, 07:52 PM   #6 (permalink)
Pic
Old 09-03-2004, 07:52 PM   #7 (permalink)
another
Old 09-03-2004, 07:59 PM   #8 (permalink)
Ok here is the deal, I replaced the sliders and lubed everything but i'm still haveing this trouble. The window goes down fine and on its way up it will jerk and stop. In order for it to go up i must push the button several times. Sometimes the window will go all the way up with no problem but rarely. When i close my door the chances of it getting all the way up is lower then if i open my door and try. Also that grey thing at the end of the motor gets pretty hot.
Could this be some connecting circuit causeing the window failure? Is my motor broken? How do i tell if its on track?
Thanks
Old 09-04-2004, 01:38 PM   #9 (permalink)
have a friend help u out on this one.. as two sets of eyes are always better then one...
open the other side so u can see a known good working system....
that should give u a lot of questions to your answers.....
make sure u order the connecting grommets for the panel... as they have a tendency to break on reinstall.. their very cheap at the dealer....
Old 09-04-2004, 02:18 PM   #10 (permalink)
I already have freinds to look at it, also the panel clips are not very cheap, they are 1.5 at the dealer. :X
Old 09-05-2004, 12:43 PM   #11 (permalink)
hall sensor i did today but it still didnt work. I also took apart the motor didnt seem like anything was wrong.
Old 09-05-2004, 01:25 PM   #12 (permalink)
uber e36's Avatar
uber e36 is an unknown quantity at this point
Send a message via MSN to uber e36
my windows will stop and go down an inch when i try to close them. at first i just tapped the button alot and it that worked (but looked stupid). then i found that if i just held the button down, they would go the whole way up....
i should get this fixed one day, but it's just a small inconvenience...
Click signature for pictures:
Need some Real Estate Advice? www.gracehomes.com
uber e36 is offline   Reply With Quote
M3 E36 Power Windows Problem vijay M-Series (M1, M3, M5, M6) 6 12-17-2004 02:09 AM
Power Window Trouble... HoFF 3-Series (E21, E30) 8 09-01-2004 04:58 PM
Window problem on a 1997 328iS bhobmw 3-Series (E36) 2 08-19-2004 10:34 AM
Power window problem. Boost 3-Series (E36) 5 06-23-2004 02:15 PM
power window problem 97328is 3-Series (E36) 4 04-12-2004 10:56 PM
