Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
Old 06-22-2004, 06:03 AM   #1 (permalink)
Boost's Avatar
Photos: 0
Boost is an unknown quantity at this point
Send a message via MSN to Boost
I'm having a problem with my power window at the driver's side of the car.
Normally on an 318is when you open the door, the window drops a half inch.
and when you close it it goes up again.
The problem is....mine stays up
Normal window operation is ok, i only have this problem when im opening the door.
Can somebody help me?
thanks in advance
Thank god I'm an atheïst
Sig under construction!
Boost is offline   Reply With Quote
Old 06-22-2004, 01:15 PM   #2 (permalink)
Photos: 0
Midnhtsun is an unknown quantity at this point
How is your drivers side window functioning are you having the same problem?
As for it not moving up as long as the window is rolling up and down properly youll be fine. I had to replace the unit on my 325is with that from a 318 and the only problem was that the windows wouldnt move up when i shut the door, like it use to.
As long as your car makes a seal and water cant leak in your fine!
Midnhtsun is offline   Reply With Quote
Old 06-22-2004, 03:32 PM   #3 (permalink)
Car: 2008 128i
Photos: 0
furious has a reset trick for the windows....
perhaps tring that would reset it/remind it what to do...
does it even try to do it anymore? any sound from window motor when you open or close it?
2008 128i Jetblack
Old 06-22-2004, 06:10 PM   #4 (permalink)
Boost's Avatar
Photos: 0
Well after is spent a day with my bimmer today, something else cought my eye, the driver's side window functions like normal (the other side works perfect too)
but the window won't go down when i open the door and stays up when i close it (only on the driver's side)
There is no indication that it's even trying (no sounds)
The weird part is that it sometimes functions like normal used
I have found a link btw... when I lock my car from a distance and the blinking lights don't blink, the door doesn't function like normal.
when i lock the car and the lights blink the door functions normally.
(The car used to blink all the time)
Also there is a squeaking noise when i shut the door (maybe it needs some grease?)
weird problem
Old 06-23-2004, 11:28 AM   #5 (permalink)
Idle Member
Photos: 0
bimerok is an unknown quantity at this point
check your fuses. if i remember correctly there is separate fuse for that
bimerok is offline   Reply With Quote
Old 06-23-2004, 03:15 PM   #6 (permalink)
Boost's Avatar
Photos: 0
I have solved the problem
I simply greased the squeaking door.
Also I put some contact spray on the joints. now it works like a charm again and doesn't sqeak anymore
Also the lights blink again when I remote lock the door.
Thanks for your help.
vB code is On
M3 E36 Power Windows Problem vijay M-Series (M3, M5, M6) 6 12-17-2004 03:09 AM
Power Window Problem ghettozn 3-Series (E36) 11 09-05-2004 02:25 PM
Power Window Trouble... HoFF 3-Series (E21, E30) 8 09-01-2004 05:58 PM
Window problem on a 1997 328iS bhobmw 3-Series (E36) 2 08-19-2004 11:34 AM
power window problem 97328is 3-Series (E36) 4 04-12-2004 11:56 PM
SEO by vBSEO 3.1.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
