Power Steering Hose And Reservior Leak - BMW Forum - BimmerWerkz.com
Old 12-04-2004, 03:24 PM   #1 (permalink)
uclabruins1996 is an unknown quantity at this point
What is the cost to replace 2 of the power steering hoses and the reservior? Is that a write up on how to do this?
What is the difficulty level?
My powersteering fluid is greyish in color (like in the picture)?
Should I be concern?
What would happen if there is no more power steering fluid? Would I still be able to turn the steering wheel?
Thanks
<a href='http://img96.exs.cx/my.php?loc=img96&image=Black.jpg' target='_blank'><img src='http://img96.exs.cx/img96/426/Black.th.jpg' border='0' alt='user posted image' /></a>
<a href='http://img96.exs.cx/my.php?loc=img96&image=Blackcolor.jpg' target='_blank'><img src='http://img96.exs.cx/img96/7590/Blackcolor.th.jpg' border='0' alt='user posted image' /></a>
uclabruins1996 is offline   Reply With Quote
Old 12-04-2004, 05:43 PM   #2 (permalink)
kearnyme's Avatar
kearnyme is an unknown quantity at this point
its not too expensive go to www.bavauto.com.
yes, but it will make loud groaning noises and likely be harder to turn.
When you replace your fluid make sure you get ATF fluid and not just the regular stuff. Generic powersteering fluid will boil. The fluid should be grayish brown.
good luck
____\_________/____
<u>/|OO| [llllll][llllll] |OO|\</u>
<u>| o |llllllllllllllllllllllllll| o |</u>
My sh*t is not disco. Thank You.
<img src='http://home.insightbb.com/~shahabm3/wsb/media/1063900/site1013.jpg' border='0' alt='user posted image' />
kearnyme is offline   Reply With Quote
Old 12-04-2004, 09:17 PM   #3 (permalink)
kvadgama is an unknown quantity at this point
What is Power Bowl? JK.
kvadgama is offline   Reply With Quote
Old 12-05-2004, 10:25 AM   #4 (permalink)
kearnyme's Avatar
used
____\_________/____
Old 12-06-2004, 02:50 PM   #5 (permalink)
noobynuub is an unknown quantity at this point
used
[snapback]243840[/snapback]
my gf has a 98 318i, the power steering just started leaking a few weeks ago and I thought it was her oil, but not. I can't seem to locate the power steering reservoir. Does anyone know? How much is not expensive to get the pump and hose replaced by someone else? keep in mind that I'm broke. ghead
Thanks
guam
noobynuub is offline   Reply With Quote
Old 12-06-2004, 03:15 PM   #6 (permalink)
kearnyme's Avatar
It should be towards the front of the car on the right side it will have an orange cap and say ATF on top.
You probably don't need a new system. Its common on these cars for the steering system to leak, most of the time it is because of the hose connected to the bottom of the resivoir there is a metal clip that gets loose and causes leakage. If you keep the resivoir filled with ATF fluid that will be fine untill you can fix the loose clip.
good luck.
____\_________/____
Old 12-06-2004, 03:18 PM   #7 (permalink)
good luck.
[snapback]244656[/snapback]
cool, I appreciate the help. I'll look into it and get back to you on that. btw, the hose and clip is underneath the car right? I might've seen it yesterday.
Old 12-10-2004, 10:15 AM   #8 (permalink)
Originally posted by noobynuub+Dec 6 2004, 02:18 PM--><div class='quotetop'>QUOTE(noobynuub @ Dec 6 2004, 02:18 PM)</div><div class='quotemain'><!--QuoteBegin-kearnyme@Dec 6 2004, 02:15 PM
good luck.
[snapback]244662[/snapback]
[/b][/quote]
Thanks, that's all it was. I replace the clip with a better clip and it stopped leaking.
