Power Steering Fluid - BMW Forum - BimmerWerkz.com
Old 01-25-2005, 10:39 AM   #1 (permalink)
fushuman is an unknown quantity at this point
Arrow
Can't find any DIY for it.
Has anyone done it? is it doable?
Cause it's 10 F out here in NY and my steering feels very stiff in the mornings and my mech would charge me 70 bucks to replace it.
Just wanna know if i could do it myself
<img src='http://www.bmw-forums.com/forum/uploads/photo-7050.jpg' border='0' alt='user posted image' />
CONQUER THE WORLD WITH YOUR <span style='color:red'>HEART</span>!!!!!
CONQUER THE RACE WITH YOUR <span style='color:blue'>SOUL</span>!!!!
fushuman is offline   Reply With Quote
Old 01-25-2005, 10:48 AM   #2 (permalink)
YoungExec728 is an unknown quantity at this point
just the fluid? bro, its cake.
Take out your airbox so you can access your power steering fluid. Then get a big syringe like 500cc (not a needle, just the syringe part) and suck out all the power steering fluid you can. Then refill it with the new power steering fluid. Then turn your car on and turn the wheel all the way to the left until it locks, then all the way to the right until it locks. Do this a few times while the car is running to get the new fluid circulating. Then, turn the car off and check the level and add as needed. Also, you can do this two or three times to ensure you get all the old PS fluid out. I really like Lucas Brank Power steering fluid, it's more expensive but worth it. Hope this helps
<img src='http://memimage.cardomain.net/member_images/9/web/741000-741999/741934_9_full.jpg' border='0' alt='user posted image' />
JC Chip * Cosmos Racing CAI * UUC System U * UUC Underdrive Pulleys * Fan Delete * UUC Sachs Stage 4 Suspension * Sway Barbarians * Racing Dynamics Front strut bar * X-Brace * Front Camber Plates * UUC TME * BBS 18x8.5 * 235/40/18 Yokohama AVS Sport * F&amp;R Zimmerman X-Drilled Rotors * SS Brake Lines * Rouge RSM w/enforcers * Clears all around * SilverStars * Pioneer Avic N-1 * Pioneer 6 Disc Changer * JL 450/4 and 1000/1 Amplifiers * 2 JL 12&quot; W6V2 * Diamond Audio Hexs 6.5&quot; in kick panel * MB Quart Premiums 4&quot; in Rear * Infinity Kappa 3.5&quot; in door * Batcap 400 * Optima Yellow Top
YoungExec728 is offline   Reply With Quote
Old 01-25-2005, 10:51 AM   #3 (permalink)
thanx man,
ill try it tomorrow
Old 01-25-2005, 11:24 AM   #4 (permalink)
Car: 1993 325i
victorgallas is an unknown quantity at this point
Send a message via ICQ to victorgallas Send a message via AIM to victorgallas Send a message via MSN to victorgallas
Originally posted by fushuman@Jan 25 2005, 11:51 AM
thanx man,
ill try it tomorrow
[snapback]278831[/snapback]
just a side note here///
BMW DOES NOT USE POWER STEERING FLUID, INSTEAD THEY USE ATF./ AUTOMATIC TRASNMISSION FLUID/!!! PAY ATTENTION TO THIS.
You are a BMW driver when you become part of the &quot;Ultimate Driving Machine&quot;
Fraude an Fahren
BMW &gt; Bayerische Motorenwerke
Auf Viedersehen der herr
www.clemsonfsae.com
victorgallas is offline   Reply With Quote
Old 01-25-2005, 11:59 AM   #5 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
Ok.. if you want to do it the right way... because the above DIY is rather half assed... meaning:.. your leaving half the fluid in the lines and the rack...
If you want to remove most of the fluid.. I've found the best way is to undo one of the hydralic fittings on the bottom of the resevoir... there are two hoses coming out of the bottom... disconnect one of them.. mainly or its best if you trace the hose that connects to your rack (its rather stiff and hard to get off.. but just work with it and it will come loose)... then let the fluid drain out... get in your car.. put the key in but dont start the car.. just unlock the steering wheel.. and turn the wheels all the way to the stop in both directions...
This will get most of the fluid ouf of the system....
If you want to remove absolutely all of the fluid.. I've found the best way to do this.. is to take off the hose the leads from the resevoir to the rack... let the resevoir drain... and let that hose drain the rack... to ensure you are removing all of the fluid.. take the other hose which runs out the bottom of the resevoir to the pump off... this will drain most of the fluid from the pump... Now you have drained the rack.. resevoir and the pump.. the only section that hasnt been drained is from the pump to the rack.. as there are three main hoses that connect the system together.. from the resevoir to the pump.. from the pump to the rack.. and from the rack to the resevoir...
Just make sure you move the steering wheel in both directions... this will ensure the rack is drained...
Good Luck,
Les
1997 E36 M3 1990 E30 325i
Old 01-25-2005, 12:01 PM   #6 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
Quick note about the hydralic fittings... if you take it off.. you may not be able to replace it... as they are rather hard to get off... most of the time they get messed up in the process... get a regular hose fitting.. one that has a flat head screw driver screw which tightens it up... that works fine for a replacement...
Good Luck again,
Les
BTW... like what was said above.. do not use power steering fluid as a replacement.. the correct fluid is ATF fluid... of a Dextron III or better...
Old 01-25-2005, 12:55 PM   #7 (permalink)
Alright, great help guys, i'll give it a try tomorrow
Old 01-26-2005, 12:58 AM   #8 (permalink)
theruss1an1's Avatar
Car: Needs momentum
theruss1an1 is an unknown quantity at this point
Send a message via AIM to theruss1an1
Im not sure if anyone said this, and if so, I missed when I was reading all your posts, sorry, but from what I know you have to use miniral based fluid. If not your seals will be eaten away. Im not sure if this is true or not but this is what I been told. Just putting this out there.
-Serge
theruss1an1 is offline   Reply With Quote
Old 01-26-2005, 01:56 AM   #9 (permalink)
drz
master of his domain
drz's Avatar
Car: zhp
Yeah, I would be careful with synthetics (i.e., I would not use them).
Turkey Fleet Bond Holder
Power Steering Fluid jones112b 3-Series (E36) 2 08-22-2005 07:53 AM
Power Steering - PS fluid or ATF Jmiller911 3-Series (E21, E30) 2 06-15-2004 09:16 PM
Power steering fluid TMac325is 3-Series (E36) 10 05-28-2004 05:20 PM
Importance of Power Steering Fluid? jlb318 3-Series (E36) 5 05-20-2004 08:42 AM
Power Steering Fluid Aether 3-Series (E21, E30) 9 04-14-2004 04:20 AM
