power steering - BMW Forum - BimmerWerkz.com
Old 04-26-2006, 05:59 PM   #1 (permalink)
WarNox's Avatar
power steering
whenever i turn my steering wheel fully left or right and press it to the end so it doesnt go anymore i can hear some motor struggling, like trying to push something further but it can't! is this normal?
then the other day i did a U-turn and all of a sudden something started squeeling whenever i turned even slightly, by now it has stopped, any ideas?
sorry its kinda hard to describe this stuff...
<img src='http://www.geocities.com/thereisnothinglikeabmw/mycar1.jpg' border='0' alt='user posted image' />
WarNox is offline   Reply With Quote
Old 04-26-2006, 07:36 PM   #2 (permalink)
tomctx's Avatar
It has a pressure release valve that opens when you turn it to the stops. I would check the fluid level if there is a squeal, even if it's stopped.
Old 04-26-2006, 10:12 PM   #3 (permalink)
WarNox's Avatar
yea ill get my steering rack changed soon then ill do it all! thnx dude!
Old 04-27-2006, 02:23 PM   #4 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
How about we check the fluid level...
Then check your tyre pressure...
Then check the system pressure...
There is no need to change the whole rack... your crazy.
Les
1997 E36 M3 1990 E30 325i
Old 04-27-2006, 03:09 PM   #5 (permalink)
Sodium Chloride
saltshaker185's Avatar
Car: 95 M3
mine does the same thing... ive even had it stall out my engine before... it worried me for a while but now i just go all the way as much as i used to... my fluid is fine... tires are also... how would i check the system pressure??
Old 04-27-2006, 03:12 PM   #6 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
You have to find a pressure checker that fits the top of the resevoir... many shops have them... easy as that.
I'm talking output pressure from the pump not standing pressure.
Les
Old 04-27-2006, 03:14 PM   #7 (permalink)
Sodium Chloride
Car: 95 M3
Les
ill look into that...
thanks, les
Old 04-27-2006, 03:47 PM   #8 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
No problem.
Les
Old 04-27-2006, 06:15 PM   #9 (permalink)
WarNox's Avatar
oh this is not why im changing the steering rack, the actual rack is broken, the teeth things are worn in the middle so its loose, its not gona cost too much, i found a 2nd hand one. and tires are fine, ill try and get the system pressure checked too!
Power steering resevoir location warrentt 3-Series (E46, E90) 5 12-05-2005 02:21 PM
Procrastination Is From The Devil: Power Steering drz 3-Series (E36) 8 04-01-2005 05:02 PM
Does An '85 318i Have Power Steering? dsio 3-Series (E21, E30) 1 03-31-2005 09:32 AM
Link Play In Power Steering BMWhatever 5-Series (E12,E28, E34, E39, E60) 0 10-11-2004 12:23 PM
