Pot holes and brake dust - BMW Forum - BimmerWerkz.com
Old 06-05-2004, 01:22 AM   #1 (permalink)
KingScare's Avatar
Car: 98 M3
KingScare is an unknown quantity at this point
Send a message via MSN to KingScare
Thumbs up
Last night, I was driving downtown and as I merged into a lane I hit a pot hole...pretty hard. The thing really caught me by surprise and I cringed as it happened.
The wheel looks fine and all...but at about 80 km/h, I can now feel like that driver side front wheel is wobbling. I do not remember the car riding like that at all....so I think something fucked up...
I don't think the wheel is bent or anything, could it be something else?
Also, my passenger side front wheel always has these black traces of something (view picture)...it looks like something the brake pads would spew out....I always notice it on that wheel...my driver side front wheel, which now wiggles at high speed, never seems to have those...
Could it be that the right side brakes harder than the left??
thank you for any help
KingScare is offline   Reply With Quote
Old 06-05-2004, 01:29 AM   #2 (permalink)
Mark31186 is an unknown quantity at this point
Send a message via AIM to Mark31186 Send a message via Yahoo to Mark31186
Hmmm im not sure what that could be... my rear right wheel does that too.... i havent hit anything but when it sits in the cold, sometimes before it warms up something vibrates... it irks the hell outta me ghead
Any suggestions on why our wheels are vibrating :P
-Mark
<span style='color:red'>- Conforti cold air intake
-Triflo exhaust
-Clear corners and tails
-Custom wheels
-Racing Dynamics stress bar
-UUC short shift kit
-Turnermotorsport Performance Chip
Soon to come - Zimmerman brakes, and suspension AND UMNITZA DDE IF I EVER GET THE GODDAMN MONEY </span>
Mark31186 is offline   Reply With Quote
Old 06-05-2004, 01:52 AM   #3 (permalink)
e285er is an unknown quantity at this point
Check your lower control arm. IT could have bent from the impact. DOes your steering wheel shake when the wheel shakes? THat could be a problem with your wheel bearings.
e285er is offline   Reply With Quote
Old 06-05-2004, 01:59 AM   #4 (permalink)
Silver4evr's Avatar
Time for a suspension inspection/testing.
Old 06-05-2004, 02:06 AM   #5 (permalink)
Speedy-325is's Avatar
check your tire for any impact bubbles, they're quite common when tires hit big bumps or potholes.
Old 06-05-2004, 07:29 AM   #6 (permalink)
KingScare's Avatar
Car: 98 M3
The steering wheel does shake...I can feel it's the driver front side wheel that's causing the shake...
I don't think the lower control arm would of broken...probably the bearing...the actual wheel and tire look fine though....no bubbles.
Old 06-05-2004, 10:42 AM   #7 (permalink)
CiscoKid's Avatar
see if the wheel threw a weight
Old 06-05-2004, 04:24 PM   #8 (permalink)
Defector
El Presidente's Avatar
the brake dust is getting wet. If it is a continual problem on just one wheel in dry conditions, you either have a leak in the engine bay or it is condensation from the AC.
Old 06-06-2004, 12:20 AM   #9 (permalink)
KingScare's Avatar
Car: 98 M3
I tried to see if any of the weights might have come off...but I couldn't spot anything weird or apparently freshly ripped off....
If I am missing a weight....would it really affect the wheel a lot?? Always wondered about that one.
So the brake dust might be getting wet eh??? It is dry conditions and it is really apparent on that one wheel, while the other one is fine.
I never put the AC on...and if something would be leaking in my engine bay...it should technically drip out as the car is idle right???
Thanks again...I'm going to see my mechanic on monday, until then, no highway driving.
Old 06-06-2004, 12:59 PM   #10 (permalink)
Defector
It doesn't have to be at idle. Say it was a small coolant leak that developed under pressure. The water pump would only pump wil the ehine was revving and put the system under pressure, thus forcing out liquid. At idle, the system would be moving fast enough to cause this.
Old 06-06-2004, 01:09 PM   #11 (permalink)
KingScare's Avatar
Car: 98 M3
I definitely never noticed anything leaking in my engine bay...
maybe I hit a puddle with that wheel...I dunno.
Would you have any other explanation for the weird dust paterns by any chance?
Old 06-06-2004, 01:15 PM   #12 (permalink)
Defector
not really. You can test this for yourself. Get the brake dust wet, but don't wipe if off. the water will make the brake dust on the wheel pull together and run, forming streaks.
Old 06-06-2004, 01:57 PM   #13 (permalink)
KingScare's Avatar
Car: 98 M3
Ok...I just came back from a test drive..
I definitely feel a shake in the steering wheel on the highway. When I hit the brakes to slow down, it was really apparent.
Also...that passenger side front wheel is just soooo dirty compared to the driver side. The car went out only twice since it was washed. That to me is just not normal. I guess my mecanic should be able to figure it all out tomorow.
The ASC and ABS lights are on all the time now in the car too...I suspect this is all linked together.
I'll post again with the diagnostic.
Old 06-07-2004, 01:57 PM   #14 (permalink)
KingScare's Avatar
Car: 98 M3
Well....I just came back from the garage...
First of all...both my front wheels needed to be balanced. *is surprised*
Then, turns out the passenger caliper was putting pressure on the rotor even when the brake wasn't pressed.
Quick rust removing and lubrification seem too have solved that problem...NOW!
I went for a test drive with the mecanic....and the wheel didn't shake at 100 kmh....
Of course...as I drive home...the wheel starts to shake again...WTF!!!!
UGH!!! I guess I'll go back tomorow and see what the deal is AGAIN!
so much for solving the entire problem.
Old 06-07-2004, 03:25 PM   #15 (permalink)
Super Moderator
dutchbmw's Avatar
That always happens...... It's just crazy............
BMW '96 M3 (SOLD)
June 2005 Car Of The Month!
Originally Posted by Torque
:help Abs Shaking While Low Speed Over Pot Holes vexlak 5-Series (E12,E28, E34, E39, E60) 0 04-03-2005 11:38 PM
Brake Rotors with holes in them? flandersmmm 3-Series (E36) 11 05-03-2004 05:26 PM
