Pod Gauge Help - BMW Forum - BimmerWerkz.com
Old 05-03-2005, 01:38 AM   #1 (permalink)
shelboo is an unknown quantity at this point
i was wondering if any of you guys have installed AIR/FUEL gauges in your beemas and if you did. did you wire it to ECU or to oxygen sensor and if that how did you do it thanx your help is very much appreciated thanx
shelboo is offline   Reply With Quote
Old 05-03-2005, 02:49 PM   #2 (permalink)
mike_e36's Avatar
mike_e36 is an unknown quantity at this point
yeah, i've done the install on an e36 with an autometer guage (which probably doesn't matter, but just in case it does). on the back of the guage you will have three wires, a 12V power wire, a ground wire and a signal wire. you attach the 12V power wire to your ignition wire, but to the one which reads 12V only after the ignition switch is in position #2, not before, my wire was green. then you attach the ground wire to any ground (just a steel nut, not painted). then run the signal wire through the firewall and down to the O2 sensor, you will want to connect it to the wire reading 0.5V when the engine is running. this wire for me was black.
it's not a very hard install, you'll find it easy, good luck.
p.s. -*** after you have installed it and want to see if it works, and it won't right away, give it around 15 seconds to warm up (it has got to warm up). if you see nothing happen after 30 seconds and your reving it a little bit, you did it wrong.
mike_e36 is offline   Reply With Quote
Old 05-03-2005, 03:15 PM   #3 (permalink)
thanxx
Old 05-05-2005, 02:50 AM   #4 (permalink)
mike_e36's Avatar
did it work ok ?
Help! A Very Headache Gauge Light Problem shuiyuan 3-Series (E36) 3 12-18-2004 09:25 PM
Recall On Fuel Gauge MaThGr82 3-Series (E46, E90) 1 10-17-2004 12:29 AM
Temp Gauge Fault expediant 3-Series (E36) 1 07-31-2004 02:40 PM
Gas gauge brien4787 3-Series (E36) 8 07-08-2004 07:02 AM
Economy gauge - has anyone got any wiring diagrams Steve (Australia) Bimmer Talk/Motorsports Talk 1 02-28-2004 10:33 PM
