Please Take a look! - BMW Forum - BimmerWerkz.com
Old 03-26-2012, 02:11 AM   #1 (permalink)
Car: 1993 318is BMW
Jbwest is on a distinguished road
Send a message via Skype™ to Jbwest
Please Take a look!
Okay so I have a 318is 1993 she's over heating every time I start her up. So I replace the radiator and still nothing, so I replace the water pump and thermostat STILL nothing. I do done this all my self and some starting to loose hope for her I don't have the money for a new engine I need some tricks of the trade I think theres a block in the block it self. I also replace my solenoid. I have no heat either please someone help.
Jbwest is offline   Reply With Quote
Old 03-26-2012, 07:39 AM   #2 (permalink)
42, The meaning of life
brettski's Avatar
Car: 2000 740iL Individual
Welcome to the Werkz.
How long does it take to start overheating?
Will it happen with it just standing and idling?
Is the top radiator hose hot and the lower hose cold?
Check if there are any kinks in the (air purge) hose that runs from the top of the radiator to the expansion tank.
Riding in style
Old 03-26-2012, 11:07 AM   #3 (permalink)
Car: 1993 318is BMW
1.)It take ruffly 10-15 min. to over heat.
2.)Its kinda jumpy after its been overheating and it's running great up until that point no stalls or issues.
3.) yes if you facing the car her top radiator hose is hot and the lower left one is cold
4.) HELPPP!
Old 03-26-2012, 03:58 PM   #4 (permalink)
Lord Vader's Avatar
Car: 1998 E36 328i
After replacing those parts did you bleed the coolant system? It's possible it's still overestig because theirs air trapped inside. Try that first.
Click HERE to see my E36 Blog
Old 03-26-2012, 11:34 PM   #5 (permalink)
Car: 1993 318is BMW
Yes I bled the system Im going try again and let you know thank you guys so much. Rep**
Old 03-26-2012, 11:42 PM   #6 (permalink)
Lord Vader's Avatar
Car: 1998 E36 328i
If possible elevate the front of the car slightly. Air rises to the highest point so if the car is raised it can help get more air out.
Old 03-27-2012, 12:31 AM   #7 (permalink)
Car: 1993 318is BMW
If this doesn't work what then maybe ?
Old 03-27-2012, 10:20 AM   #8 (permalink)
Lord Vader's Avatar
Car: 1998 E36 328i
Low coolant? A leak somewhere? Or a clog?
If it still persists your gonna have to inspect your hoses and clamps looking for leaks and feeling them for a blockage or buildup. The top radiator hose should be hot and the bottom should be cold.
Old 03-27-2012, 10:48 AM   #9 (permalink)
Lord Vader's Avatar
Car: 1998 E36 328i
This Is the Pelican Parts article on coolant changes and coolant systems.
Pelican Technical Article: BMW 3-Series E36 Cooling System Flush
Old 03-27-2012, 04:24 PM   #10 (permalink)
Car: 1993 318is BMW
Im thinking clog but for the simple fact that I have done the bleed just maybe not correctly but I will try again and jack the car up this time. The top hose is extremely hot but the bottom is relatively cold. Im not sure if its electrolysis cause there was some damage on my thermostat housing but not to bad. How do you get rid of electrolysis though?
Old 03-27-2012, 04:44 PM   #11 (permalink)
Lord Vader's Avatar
Car: 1998 E36 328i
How to get rid of it is covered in the link above. Their are obvious signs of it, but only once it's done some significant erosion damage.
Old 03-29-2012, 03:57 PM   #12 (permalink)
Car: 1993 318is BMW
It didn't work it's still over heating
Old 03-29-2012, 04:40 PM   #13 (permalink)
Lord Vader's Avatar
Car: 1998 E36 328i
How was the coolant level? Check the oil, and look for what color it is. If it looks milky brown (like coffee with cream) then you have a head gasket blown.
