Please Help, 325i ?. 1st timer - BMW Forum - BimmerWerkz.com
Old 02-05-2009, 05:09 PM   #1 (permalink)
GSREX is on a distinguished road
So i picked up a super clean black 325i the other day, for what I thought was a good deal. On the way home, it started running rough. Looked into it the next day, and my number 6 cyl isnt firing.
I've already swapped the plugs, which were all covered in oil. I would imagine from high mileage.
I've swapped coils back and forth, they are all working.
I've also swapped injectors, and they are all flowing.
My coolant is clear, and my oil is Black. So i dont believe its my head gasket. But I need input please! Greatly appreciated
GSREX is offline   Reply With Quote
Old 02-05-2009, 05:18 PM   #2 (permalink)
Oh and I should probably state, Its obviously running on probably only 5cyl, It idles rough and sputters. No smoke, CEL's, nothin.
Old 02-05-2009, 07:17 PM   #3 (permalink)
Science Roolz!
Car: 2011 Mazda2, 1990 Miata
So you THINK cylinder #6 isn't firing. Take it to a shop man, you need some professional help.
2011 Mazda2
1990 Mazda Miata
Old 02-05-2009, 07:43 PM   #4 (permalink)
mheidemanjr's Avatar
Car: 1994 bmw 318i
mheidemanjr is on a distinguished road
Send a message via AIM to mheidemanjr
Smile
yeah and dont forget the vasoline buddy
mheidemanjr is offline   Reply With Quote
Old 02-05-2009, 07:46 PM   #5 (permalink)
I dont want to be charged an arm and leg to have it looked at or fixed. There is only so many things it could be, There is a low mileage M50 motor for sale local here for $600. It might just be worth it to swap?
Old 02-05-2009, 07:57 PM   #6 (permalink)
Car: 1994 bmw 318i
well id give it a day or 2 thir are a lot of smart bmw guys on here 325 is not my strong point they might be able to help ya
Old 02-05-2009, 09:01 PM   #7 (permalink)
Science Roolz!
Yeah I'm one of them...BUDDY. If the car was running on 5 cylinders it would be throwing codes out the ass, and he said there's no cel. Oil covered spark plugs probably valve cover gasket, that's very BASIC stuff. It could be as simple as a vacuum leak. Have fun.
2011 Mazda2
1990 Mazda Miata
Old 02-05-2009, 09:11 PM   #8 (permalink)
Im not illiterate, no where near a noob. Your telling me my valve cover gasket, is going to fix the oil on the bottem electrode part of the plugs?
Old 02-05-2009, 09:18 PM   #9 (permalink)
If that much oil is getting to the plugs past the piston rings... Well that would be pretty bad.
Old 02-05-2009, 09:34 PM   #10 (permalink)
Science Roolz!
Yeah I am, if you weren't a noob you'd think of that first, is the oil wet or is it dried up residue, basically if there's oil on your plugs it's either valve cover or piston rings, which would you like to replace first Mr. Non-Noob. Also it's you're not your and at no point did I say you were illiterate. I'm just telling you to take it to a shop for some professional diagnostics before you waste your time and money. I'm trying to HELP you believe it or not.
2011 Mazda2
1990 Mazda Miata
Old 02-05-2009, 10:02 PM   #11 (permalink)
Ich bin der Modifikator
johnnyBgood's Avatar
Hi, GSREX....if you have oil in the very tip of the sparkplugs, your car would definitely be smoking....are you sure it was not just excess oil that dripped down, because the valve cover gasket is known to harden, crack & then leak down in this area.....also, wondering if maybe the CEL bulb was maybe removed....or maybe just blew out...easy check would be just to turn the ignition switch on.....I do agree, if the engine was running on 5 cylinders, there would be a CEL. In reading everything you have done so far, such as:
So, if you are sure you have heavy black oily carbon deposits on the spark plug electrodes & in the combustion chambers, this would tell you that the engine is burning oil. The most likely cause is worn valve guide seals and/or guides, but worn rings and cylinders can also allow oil to enter the combustion chamber. The only way to be sure is to do a compression test on each cylinder......I am not so sure this your problem though, because like I said you would have a smoking condition.....???
johnny,
Old 02-06-2009, 04:07 AM   #12 (permalink)
johnny,
Johnny, Thanks for your input it is Greatly appreciated. When I first pulled the plugs, they were just drenched in oil. More so on the bottom from the combustion chamber, but the grommets on the valve cover are also obviously leakin a tad. Oddly enough, there is No smoke. Not upon start up, while driving or under a heavy load. Nothin. I figured maybe someone had disconnected the CEL light, but it does turn on when the car is in the "on" accessory position.
Old 02-06-2009, 09:26 PM   #13 (permalink)
No problem, if you have any more questions just post or pm me...... what's your next move?
johnny,
Old 02-06-2009, 09:50 PM   #14 (permalink)
Car: 1994 e34 525
coolvegase34 is an unknown quantity at this point
didn't you take the car to a mechanic for an inspection? That is the first thing that you should do. Bmw's are the best, but any car that is not inspected by a professional mechanic prior to purchase, you are asking for trouble. When I bought my e34 1994 525i, it had 78,000 miles on it, all the service records for the past 14 years(receipts), was in mint condition and I still took it to my mechanic and paid $90 for him to check it out. He pulled the whole car apart and when he asked me if I wanted to sell it to him, I replied that I was trying to purchase it. His offer confirmed that the car was a good buy.
coolvegase34 is offline   Reply With Quote
1st day of the year 1st problem kman Picture Showroom 17 01-03-2007 08:34 PM
1st Post: Thinking Of Buying 93 325i streetdreams 3-Series (E36) 5 11-22-2004 08:04 AM
whats the timer under the RPM timer? shuiyuan 3-Series (E36) 5 08-31-2004 11:18 PM
Trip Timer in the 04 325i? jbone66 3-Series (E46, E90) 0 07-30-2004 11:21 AM
hello all im a 1st timer hodges76 3-Series (E46, E90) 0 12-31-1969 07:00 PM
