Originally Posted by Pro Turbo my problem still exist...
i scanned it and see the current data... when the engine idle...
and the TPS 0.00V even though i stepped on the gas...
The Air Flow... stays at 518 mm/HG if not mistaken...
and the Air Temperature and engine temperature at 198.5 deg....
what u suggest??
should i change the parts or the DME or the wiring damaged?
PLS Help |
what year?
what is the rest of the scanner data you have?
O2 sensor voltage?
color of electrodes of spark plugs?
corroded terminals at MAF &/or TPS connectors. or main connector at engine harness.
*TPS voltage be checked by measuring voltage at varied pedal positions.. increase in voltage directly proportional to increased pedal position
*MAF airflow voltage should also vary upwards with pedal position change
*02 sensor voltage should also play between 250mv to 800mv at idle.
... if both are acting erratically... and u have access to a spare, try a different ECU ;-)
... check also CAT-could be partially closed!(always happens. bimmer weakness)
