Platinum IR Fusion Spark Plugs - BMW Forum - BimmerWerkz.com
Old 08-20-2007, 08:33 PM   #1 (permalink)
agtur2001's Avatar
Car: 1994 325ic
agtur2001 is an unknown quantity at this point
Question Platinum IR Fusion Spark Plugs
Guru's,
I installed four Bosch IR Fushions in my 1993 318is a year ago and the engine blew a cylinder within a week. Sold that car while running like shit and bought a 1994 325i. I installed 6 Bosch IR Fushions in my 94 325i last week while changing the oil. Now the car is miss firing/stalling and basically not wanting to run. The engine light turns on and off and I have to rev the car to 3k just to keep it from stalling.
What is the deal with the Bosch IR Fushions? Or am I just having bad luck?
Comments, suggestions.
Please help!
agtur2001 is offline   Reply With Quote
Old 08-21-2007, 03:08 AM   #2 (permalink)
bimmerguy82's Avatar
Car: 2004 ZHP 6SPD
Huh, sounds odd. maybe coincidence but I'd stick to NGK or regular Bosch plugs.
BMWcrazy
___________
-Joshua
BMWCCA member#407674
Old 08-21-2007, 06:58 AM   #3 (permalink)
Mr. Bacon
dannyb's Avatar
Car: '08 Rabbit / E30 325is
dannyb is a glorious beacon of lightdannyb is a glorious beacon of lightdannyb is a glorious beacon of lightdannyb is a glorious beacon of lightdannyb is a glorious beacon of lightdannyb is a glorious beacon of light
Send a message via MSN to dannyb
I used NGK Iridium and the car is running fine, maybe you should try that. Stupid question, but did you get the right sparkplugs?
Originally Posted by german-speed-demon View Post
that's my whore ; )
dannyb is offline   Reply With Quote
Old 08-21-2007, 07:39 AM   #4 (permalink)
WarNox's Avatar
yea, you sure you got the 'double headed' ones?
<img src='http://www.geocities.com/thereisnothinglikeabmw/mycar1.jpg' border='0' alt='user posted image' />
WarNox is offline   Reply With Quote
Old 08-21-2007, 06:24 PM   #5 (permalink)
Kissner's Avatar
Car: 1998/BMW/M3
Kissner is on a distinguished road
Send a message via Yahoo to Kissner
I have those plugs in my M and i haven't had any problems. As long as you bought the right plug i think it's just a coincidence. Try NGK
Kissner is offline   Reply With Quote
Old 08-21-2007, 06:34 PM   #6 (permalink)
BMWJNKY's Avatar
Car: '89 E30 w/M50
My thought on spark plugs is that unless you have something crazy done to the engine, boost/stroker/cams, I don't see a reason to switch from the spark plug BMW put in the engines from the factory. The factory plugs are going to be the right heat range, right resistance and have the right reach into the cylinder. I run the factory plug in my M50 with CAI, chip, pullies and cat back and have had zero missfire issues.
My M50 Powered E30 Page
Old 08-22-2007, 03:54 PM   #7 (permalink)
agtur2001's Avatar
Car: 1994 325ic
Guru's...
Quick update: Turns out that my Mass Air Flow Sensor is the problem. I guess it really was bad luck... the car runs Perfect until I decide to do some maintenance work on it!!! CRAZY! The plugs are correct and defintely not the problem.
So, has anyone replaced a Mass Air Flow Sensor? I am picking one up tomorrow and was planning on installing myself. It seems pretty basic.
Thanks everyone!
NKG vs BOSCH spark plugs lsatdown 3-Series (E36) 2 07-13-2006 11:40 PM
choice in spark plugs for 95 740i e38 kc740i 1,6,7,8 - Series and Mini Cooper 2 11-13-2005 10:12 AM
Bosch Platinum +4 Spark Plugs hpacc 5-Series (E12,E28, E34, E39, E60) 23 12-06-2004 08:57 PM
BMW spark plugs Autotechnica 3-Series (E36) 36 08-18-2004 07:22 PM
