Passenger Side Window Won't Roll Up. - BMW Forum - BimmerWerkz.com
Old 04-16-2005, 09:15 PM   #1 (permalink)
mvelimir is an unknown quantity at this point
My pass. side window will roll down, but it'll not go up. I can hear motor whiring, but it'll not move. I have to pull it up with my hand.
I checked a lot of threads regarding this problem, so today I took the door panel off, disconected glass panel from the regulator by unclipping the regulator arms from window glass slides, and secured the glass in up position. Tried the regulator on it's own, and everything works fine. One click open - works, One click close - works. So I mounted glass again, and same old problem. I'm puzzled now.
Any ideas?
Thank you.
mvelimir is offline   Reply With Quote
Old 04-17-2005, 12:08 AM   #2 (permalink)
Tom Busby is an unknown quantity at this point
The regulators have plastic gears that can slide out of alignment. Your works when it doesn't have any weight to move? Replacing the whole regulator is likely to be the fix.
Tom Busby is offline   Reply With Quote
Intermitient Operation Of Drivers Side Door Window mudilik 5-Series (E12,E28, E34, E39, E60) 1 08-18-2005 09:56 PM
Driver Side Window Problem Crispy222 3-Series (E36) 6 03-11-2005 03:23 PM
Passenger Window Exterior Trim epistemology 3-Series (E36) 5 09-27-2004 03:28 PM
Passenger side window rides out swindon_matt_uk 3-Series (E36) 2 09-08-2004 12:29 PM
Driver Side Window Won't Seal bren 3-Series (E36) 3 07-07-2004 11:13 AM
