Passenger Door Panel
1K views 4 replies 5 participants last post by  RIBEMR26
#1 ·
What do I need to do to remove the passenger side door panel?
#3 ·
torx screws are located under tabs behind the interior handle...the pannel pulls off after that, use a screwdriver or if you have the luxury you can use a large serparation tool. be carefull when you take it off, do it slow as to not break any of the clips
#5 ·
http://www.logun.org/door.htm
I guess maybe buy some extra clips before the job, apparently they are pretty easy to break...I have to do this in a few weeks to replace Drivers side door actuator
