Passenger Door Latch. - BMW Forum - BimmerWerkz.com
Old 01-21-2005, 01:03 PM   #1 (permalink)
Casey3561 is an unknown quantity at this point
Thumbs up
Well, recently my passenger door trim starting coming loose. No big deal, I replaced the black trim on the inside, and it seems to hold fine so far. The old one was worn anyway.
Now, the annoying problem. On the 318is, the window opens slightly when the door opens or closes, and closes fully when the door shuts. My driver's door is just fine, but my passenger door only latches fully about half the time. Thus, the window only seals about half the time. Last night, I spent 20 minutes in 0F trying to find any dirt or crap in the window track so the window would close.
I went over the latch with a rag and got out a lot of black crud, but is there anything else I should try? Hose it down with WD40 and see if it's just dirty?
Thanks.
Proud member of the 100,000 mile club
Proud member of the I Hate SUVs club
Casey3561 is offline   Reply With Quote
Old 01-22-2005, 12:49 AM   #2 (permalink)
Car: 1993 325i
victorgallas is an unknown quantity at this point
Send a message via ICQ to victorgallas Send a message via AIM to victorgallas Send a message via MSN to victorgallas
Thanks.
[snapback]276162[/snapback]
whe the window does not go up, stays down, does the door lock? or it just unlocks itself right afterwards...
If its only the window, then the position sensor on the window motor lift is gone, you can put it back on place, but it fail again, so a new motor is the best solution.
in case the door lock unlocks when the window also wont go up, is because there is a swicth on the door lock mechanism that fails, this swicth tells the door that is open, so it puts the window down and it wont let it lock..
once you close the door, it will make contanct ,letting the motor knwo the door is closed, so it put the window up and also permit the lock to lock.
for above procedures, they are all on the web and also on this forum..,. ive posted on anoteher convertible that had same issues.
coupes, convertibles share the same sytem, and then problems.
let me know if more help is neede.
You are a BMW driver when you become part of the "Ultimate Driving Machine"
Fraude an Fahren
BMW > Bayerische Motorenwerke
Auf Viedersehen der herr
www.clemsonfsae.com
victorgallas is offline   Reply With Quote
Old 01-22-2005, 09:04 PM   #3 (permalink)
It's the second of the problems. It'll latch, but only halfway. I'm going to go over it with a can of WD-40 and see if the latch loosens up.
What would I search for to find out how to replace or clean out that latch mechanism?
Old 01-22-2005, 09:38 PM   #4 (permalink)
Car: 1993 325i
[snapback]277154[/snapback]
search for e36 door lock mechanism, i belive.
pretty much youll pull out all the whole lock mechanism out of the door...
and since youre going to be at it. then rreplace the swicth that ive talk about.l
Fraude an Fahren
www.clemsonfsae.com
Old 01-23-2005, 03:51 PM   #5 (permalink)
Car: 1993 325i
hey
this is what you need form the dealer..
but this microswicth only applies to convertibles and coupes, because the window has no metal frame on top, so it needs to know when to drop the window.
on sedans, the siwcht is not there, the only swicht that there is is located on the striker, so if its a sedan and is asking weird, than just look for the striker.
hope this pics helps.
Fraude an Fahren
www.clemsonfsae.com
Old 01-23-2005, 03:53 PM   #6 (permalink)
Car: 1993 325i
hey
Fraude an Fahren
www.clemsonfsae.com
Old 01-23-2005, 03:56 PM   #7 (permalink)
Car: 1993 325i
hey
[attachmentid=17579]
Fraude an Fahren
www.clemsonfsae.com
Old 01-23-2005, 05:42 PM   #8 (permalink)
Car: 1993 325i
hey man i found the DIY link fo rthis repair, have fun
http://home.earthlink.net/~frankie66/cars-...icroswitch.html
and this other link is a link for several DIY link..
http://www.geocities.com/e36rulz/DIY.html
let me know how it goes.
Fraude an Fahren
www.clemsonfsae.com
Old 01-23-2005, 07:05 PM   #9 (permalink)
I'm washing it tomorrow once it gets warmer, then I'll clean out the latch and window track. Hopefully it's just some crud that's keeping it from hitting right.
Old 01-25-2005, 06:52 PM   #10 (permalink)
Well, I finally got around to washing it (38 degrees! Yay!), and the problem is solved. Took a lot of crud out of the latch area with a clean rag, wiped it out and lightly oiled it with mineral oil, and it works sweetly as ever. Cheap fix.
Old 01-25-2005, 08:27 PM   #11 (permalink)
drz
master of his domain
drz's Avatar
Car: zhp
[snapback]279166[/snapback]
Cool. It's good to know that worked for you.
Turkey Fleet Bond Holder
Dead Passenger Side Hypnogaja 3-Series (E21, E30) 5 10-21-2004 03:29 PM
Passenger Window Exterior Trim epistemology 3-Series (E36) 5 09-27-2004 03:28 PM
Passenger heat jwb 1,6,7,8 - Series and Mini Cooper 1 08-18-2004 06:36 PM
Airbag Deactivated with Passenger Miami545 5-Series (E12,E28, E34, E39, E60) 5 06-21-2004 08:15 PM
Passenger Side Mirror Question Exacc 3-Series (E46, E90) 0 04-19-2004 11:28 AM
