part number for ac and aux fan relays(already did search and called dealer - BMW Forum - BimmerWerkz.com
Old 06-13-2006, 03:42 PM   #1 (permalink)
miami325e is on a distinguished road
could you guys check on your e36 and tell me the part number and color of the relay in your fuse box in positions 13,14,15. I need these relays and i dont even know which ones are they. thank you.
miami325e is offline   Reply With Quote
Old 06-13-2006, 08:39 PM   #2 (permalink)
I don't know if this will show up but here's the diagram out of the factory TIS manual for the relays. Do you need actual part numbers off the relays themselves?
Mike
Hamfisted is offline   Reply With Quote
Old 06-13-2006, 10:41 PM   #3 (permalink)
Yes!i Need The Actual Part Number Off Relays!!!please!!!
Old 06-14-2006, 10:27 AM   #4 (permalink)
drz
master of his domain
drz's Avatar
Car: zhp
check www.realoem.com
Turkey Fleet Bond Holder
Old 06-14-2006, 12:19 PM   #5 (permalink)
again real oem doeent specify what relay is for what, i need someone to pull the actual relay and get the number, o
Old 06-14-2006, 01:40 PM   #6 (permalink)
Retired administrator
triggrhaapi's Avatar
Hamfisted, can you check ETK?
Addicted to Speed Since 1997
Old 06-14-2006, 04:38 PM   #7 (permalink)
Just to clarify....
You want the X51, X52, X53 relays from the picture above?
What year and model is your BMW exactly? Cooling fan control relays?
Could you give the last 7 digits of the VIN number? Thanks.
Mike
Old 06-14-2006, 07:22 PM   #8 (permalink)
yes please, 1993 bmw 325is, yes, cooling fan control relays and ac compressor relay. Last 7 are EF39033
Old 06-14-2006, 10:30 PM   #9 (permalink)
Ok here goes nothin .....
Ok, '93 325is manual tranny car.
The relay in spot X51 is BMW p/n 61.36.138.8911
It's a standard Siemens relay and the Siemens p/n is V23134-E59-X107.
The relay in spot X52 is the same as the relay in spot X53 and those relays are BMW p/n 61.36.138.9105 .
Or Siemens p/n V23134-K52-X181
The relays are made for BMW by Siemens and they have both part numbers displayed on the outer case (as well as the function diagram...).
Relays X52 and X53 are identical so you would be safe swapping them around.
Hope this helps.
What was wrong with yours originally? You'll probably have to get these at the dealer or a junkyard. Good luck.
Mike
Old 06-14-2006, 11:03 PM   #10 (permalink)
my car doesnt have them
Old 06-15-2006, 02:30 PM   #11 (permalink)
No A/C ?
You didn't have A/C in your car? Or somebody thought they knew better than the engineers that designed it?
Mike
Old 06-15-2006, 05:58 PM   #12 (permalink)
somebody give hamfisted some reputation. I would, but I can't.
Old 06-15-2006, 07:24 PM   #13 (permalink)
drz
drz's Avatar
Car: zhp
so done
