Paint Rolled/Popcorn Effect - BMW Forum - BimmerWerkz.com
Old 06-19-2007, 06:39 AM   #1 (permalink)
Mr. Bacon
dannyb's Avatar
Car: '08 Rabbit / E30 325is
dannyb is a glorious beacon of lightdannyb is a glorious beacon of lightdannyb is a glorious beacon of lightdannyb is a glorious beacon of lightdannyb is a glorious beacon of lightdannyb is a glorious beacon of light
Send a message via MSN to dannyb
Exclamation Paint Rolled/Popcorn Effect
Some of the paint looks like it was rolled with a roller, some people call it the popcorn. You can only see it when looking at some angle. Is there a way of fixing this?
Originally Posted by german-speed-demon View Post
that's my whore ; )
dannyb is offline   Reply With Quote
Old 06-19-2007, 04:56 PM   #2 (permalink)
Crazy Fabricatin' Admin
gotKRAUT's Avatar
Car: '87 325es M50tu Swapped
?? you mean its not smooth? if so the only way to fix it is with stripping it down and repainting it....being that our car has a clear coat no abrasives or wet sanding will be possible...
but if its original paint i have no idea what you are talking about?!
Pics?
Kyle Sutherland
1995 BMW 540i/6:
The Calypso Beast Vid 0-70ish
E34 Plate Filler Wanted!
Old 06-19-2007, 07:35 PM   #3 (permalink)
BMWMTECHNIC's Avatar
Car: 89 e34 02 X5 03 Z71
BMWMTECHNIC is on a distinguished road
Is it "ORANGEPEEL"
Somnetimes they call it Orange Peel because it looks like the surface of an orange..
some of that sometimes buffs oout.. best bet is to take it to a body shop.. Either they can fix it or you can get an estimate on getting it repainted!
BMWMTECHNIC is offline   Reply With Quote
Old 06-19-2007, 07:37 PM   #4 (permalink)
Mr. Bacon
dannyb's Avatar
Check out the first pic on http://www.bimmerwerkz.com/forum/pic...8-a-52813.html
It's hard to see... Repainting, that would be expensive :|
Weird thing is the hood, trunk and roof look great but the doors just look weird.
that's my whore ; )
Old 06-20-2007, 12:22 AM   #5 (permalink)
gotKRAUT's Avatar
thats orange peel, if you have a clear coated paint job even a good shop will tell you the same thing, not much they can do...usually its underneath the clear coat, so you have to polish/wet sand through the clear coat and then the base coat to fix it...
if this is a factory paint job this shouldnt be there...just pay a professional detailer to do a good polish job, usually takes about 4-6 hours with various abrasives and a Professional Grade Polisher and costs around $200 but the result is miind boggling...
keep in mind, nothing will completely remove the orange peel except a better paint job
Kyle Sutherland
1995 BMW 540i/6:
Old 06-20-2007, 06:09 AM   #6 (permalink)
Mr. Bacon
dannyb's Avatar
Thanks I'll have it detailed and see the results. How much do you think repainting would cost? My friend paid over 2k to get his Golf repainted... too bad he still got accidents after that...
that's my whore ; )
Old 06-21-2007, 03:23 PM   #7 (permalink)
gotKRAUT's Avatar
honestly, $2k is on the cheap end with prep work...prep work and good paint job is around $4k for something decent, i went a step further, i think the beetle with me doing all the prep work(not recommended unless very skilled) cost about $4k just for the paint job alone...
the finish is FLAWLESS though...and it was a full job, windows out, full interior out, fenders all off deck lid off bonnet off no engine no gas tank, etc....
just rolled up the frame, body and then all the pieces to be painted hah
Kyle Sutherland
1995 BMW 540i/6:
Old 06-21-2007, 04:42 PM   #8 (permalink)
Mr. Bacon
dannyb's Avatar
Im keeping it black so id probably only repaint the outside no need to take everything you... You just had to do it version 2.0
ill try to find a deal through some contacts... Apparently after speaking to a bmw club owner, the e36 and up paint isnt that good and is mainly the reason for it to do that...
that's my whore ; )
Old 07-11-2007, 11:04 PM   #9 (permalink)
seven is on a distinguished road
Finally something I know a lot about. Sounds to me the car was repainted by someone who tried to do the job quick. The hood roof and trunks looks good because the paint flowed out on a flat surface. the sides are vertical and cannot take as much paint without running. There is a slight possibility the car can be wet sanded with 2000 grit paper but unlikely without burning through the clear coat. Best bet would be wet sand and reclear. If you can save the base coat painting the roof and hood and trunk would not be neccesary
seven is offline   Reply With Quote
Old 07-13-2007, 01:22 PM   #10 (permalink)
Keep it Copacetic
///M Power's Avatar
Car: 1995 BMW M3
Maybe you can try adn smooth it out with claybar? And yes I realize how old this topic is.
Old 07-16-2007, 06:16 AM   #11 (permalink)
Mr. Bacon
dannyb's Avatar
Ill have it detailed, clay polish seal wax, and see if that fixes it. If not, I'll try wet sand and reclear and if that doesnt work well I'll just repaint it later.
that's my whore ; )
M6 Paint Problem Nightmare ilushka85 M-Series (M1, M3, M5, M6) 1 01-18-2007 01:10 AM
Turtle wax chip stick steve325IS Wash & Detail 10 06-22-2004 11:56 AM
PROTECTING PAINT Ski Wash & Detail 2 05-28-2003 08:31 AM
