P0455 - Help - BMW Forum - BimmerWerkz.com
Old 08-13-2008, 02:51 PM   #1 (permalink)
staro03 is on a distinguished road
P0455 - Help
Ok..I am now forum jumping for the answer to my curse of P0455. Where is the EVAPORATIVE PURGE VALVE on a 1998 BMW 318i SEDAN?????
It is not the GAS CRAP! Cap?
Thank you for all your help
Bob
staro03 is offline   Reply With Quote
Old 08-13-2008, 04:56 PM   #2 (permalink)
darkhorse737's Avatar
Car: 88 super ETA, 95 525i
Talking
by the Left Hand Shock Tower.
just follow the lines from the canister and you're sure to find it
Old 08-13-2008, 06:02 PM   #3 (permalink)
Thank you! I will go check this now. This has been a troubling code! It is the only code tha pops up so I believe the sensors are ok. I am hoping a hose fell off broke or just aged apart. Any other ideas would be appreciated. The Gas Cap and Oil Caps have been replaced.
Bob
Old 08-13-2008, 06:33 PM   #4 (permalink)
Wink
Bob
... a bad seal between gas cap and filler hole will set P0455 as well. Pay close attention to that part of your filler pipe where the gas cap seal rests.... in some cases, they get damaged from jamming the gas dispenser into the filler hole, so that even if gas cap is new(or wrong spec), it still won't seal right...
Good luck
Old 08-13-2008, 06:40 PM   #5 (permalink)
Thank you! I will check this closely with flashlight. This is simply driving me NUTS!
Old 08-13-2008, 09:13 PM   #6 (permalink)
YEAH!!!!! At least the Blue Hose went all the way to front and was SPLIT about 8" to the valve. It is fixed easily. The P0455 LEAK code appears to just that! a LEAK no electronic problems.
Thank you all for your Help!
P0455 wulley1 3-Series (E36) 6 11-14-2005 12:38 PM
