Oxygen sensors? Help! - BMW Forum - BimmerWerkz.com
Old 07-17-2006, 09:42 PM   #1 (permalink)
larsenbh is on a distinguished road
Hello there,
I have a 92 325i that runs really sluggish. The engine sounds like it's doing very well mechanically, but it holds back and has small explosions in the exhaust. If I only press the gas pedal slowly, it will be fine, but once I floor it it sounds very sick.. I bought the scan tool from Bavarian and it says oxygen sensor (code 46). I replaced the oxygen sensor yesterday (took me forever because it was stuck - any tricks on how to replace this easier are apreciated) and it didnt help at all. However, it makes sense that it is the oxygen sensors, because sometimes it will be fine for the first 10 seconds or so after I start it and according to the Bentley book, the oxygen sensors aren't active until the engine is warm. I also checked the oxygen sensor heater relay, and it's fine. Where do I go from here?
larsenbh is offline   Reply With Quote
Old 07-18-2006, 12:05 PM   #2 (permalink)
paco1076's Avatar
Car: 1997 BMW M3
paco1076 is on a distinguished road
Send a message via AIM to paco1076
Have you ever changed the cat. converter? Those get clogged over time and won't run right. When you press on the gas, does it sound like it wants to run, but doesn't get up and go? Sounds like someone put a banana in your tail pipe?
Or does it just run rough?
1997 E36 M3 - running stocker style right now...
paco1076 is offline   Reply With Quote
Old 07-18-2006, 12:15 PM   #3 (permalink)
LOS
LOS's Avatar
Car: 97 540IA, 95 840CI
Try hitting the cat. and if you hear a rattle then it's time to replace them.
Bavauto has a tool (socket) to ease replacing the sensor for abot $19.
Also, I have heard some small autopart stores will let you borrow it!!
LOS
2000 528i 'oxygen sensor adaptation limit' sreitshamer 5-Series (E12,E28, E34, E39, E60) 8 02-14-2012 05:15 PM
Oxygen Sensor DatBxE36 3-Series (E36) 8 07-13-2006 04:50 PM
Need Help With Oxygen Sensor Part superdeadman 5-Series (E12,E28, E34, E39, E60) 4 06-13-2005 08:10 PM
Location Of O2 Sensors J.Bassler 3-Series (E36) 7 02-04-2005 02:12 PM
