Oxygen Sensor Problem - BMW Forum - BimmerWerkz.com
post #1 of 5 (permalink) Old 06-14-2005, 11:52 PM Thread Starter
sto150 is an unknown quantity at this point
Need some advice. I tried to change my O2 sensors after the cat on my '97 328i and I can't get the wrench on it because of the angle. They are directly on top of the exhaust and there is no way the O2 socket will fit. The crescent wrench (not the ideal tool but I couldn't find a wrench that large ... 22mm??) wouldn't get a good grip. How can I get to these??
sto150 is offline
post #2 of 5 (permalink) Old 06-15-2005, 02:28 AM
Been here a while.
97alpineM3's Avatar
97alpineM3 is a name known to all 97alpineM3 is a name known to all 97alpineM3 is a name known to all 97alpineM3 is a name known to all 97alpineM3 is a name known to all 97alpineM3 is a name known to all
Your O2 sensors are in a different location than mine... I'd just remove the exhaust let it hang a bit and see if that will help... its rather easy unless your exhaust is old and rather rusted... try a few other tools... and remove the exhaust as the last resort...
Good Luck,
Les
1997 E36 M3 1990 E30 325i
97alpineM3 is offline
post #3 of 5 (permalink) Old 06-15-2005, 08:35 AM
napalm is an unknown quantity at this point
Good Luck,
Les
[snapback]353652[/snapback]
I did it this way also. I removed the rear two exhaust brackets off the muffler. However these were old and broke, so I had to make two new ones by drilling out the bolts and replacing them.
Remember, when you let the exhaust 'hang' you are putting weight and pressure on your header under the hood. Try to keep a jack stand directly under the exhaust just as it comes down out off the motor.
Cracked header = bad times.
napalm is offline
post #4 of 5 (permalink) Old 06-15-2005, 11:59 AM
mech9T8's Avatar
mech9T8 is an unknown quantity at this point
I have a 96 328 and had to replace one of the rears. I was able to do it with a crescent wrench.
Your right though, it is a tight space.
<img src='
<span style='color:blue'>My ass may be dumb, but I ain't no dumb ass!</span>
mech9T8 is offline
post #5 of 5 (permalink) Old 06-16-2005, 09:17 PM Thread Starter
Thanks for the replies. I found a 22mm wrench at AutoZone and I was able to get at them without dropping the exhaust.
sto150 is offline
2000 528i 'oxygen sensor adaptation limit' sreitshamer 5-Series (E12,E28, E34, E39, E60) 8 02-14-2012 06:15 PM
narroww band oxygen sesor?? buuhh99 3-Series (E36) 4 10-17-2005 05:12 PM
Need Help With Oxygen Sensor Part superdeadman 5-Series (E12,E28, E34, E39, E60) 4 06-13-2005 09:10 PM
Bmw 325 Is Oxygen Sensor Help!!!! fryebzky 3-Series (E36) 2 10-14-2004 06:45 PM
