Oxygen sensor - BMW Forum - BimmerWerkz.com
Old 09-10-2004, 12:11 PM   #1 (permalink)
mech9T8's Avatar
mech9T8 is an unknown quantity at this point
So my check engine light goes off and the dealer says I need to replace the O2 sensor. They wanted about $350 CAD.
So I thought I would do it myself and while I was at it I would replace all 4. But after seeing what one of them costs I decided not to.
What I need to find out is which one is faulty. The dealer told me that it is the sensor from bank #2. So are these the ones before or after the cat? Anyone know? Is there a way to test them? I found out that all 4 sensors are identical but then I also found that there are some with short wires and some with longer wires. So which one do I get?
I thought that if I get the one with the longer wire I would be safe because it would reach to the connector regardless.
Any help would be much appreciated.
<img src='http://www.geocities.com/royb9t8/MY_BMW_2.jpg' border='0' alt='user posted image' />
<span style='color:blue'>My ass may be dumb, but I ain't no dumb ass!</span>
mech9T8 is offline   Reply With Quote
Old 09-10-2004, 12:29 PM   #2 (permalink)
Sk1d's Avatar
Sk1d is an unknown quantity at this point
I'm assumin u've either got a straight six or a v8 in ur Beemer. Bank 2 meaning one side of the exhaust system or the other. If u can speak 2 ur mechanic again n ask him if its the upstream or downstream sensor ur sorted. After that its a DIY job...
Me-Chanic
Sk1d is offline   Reply With Quote
Old 09-10-2004, 01:05 PM   #3 (permalink)
mech9T8's Avatar
I have a 96 328.
I don't think the dealer will be that willing to give up the info.
But I can always try.
Old 09-10-2004, 01:37 PM   #4 (permalink)
/Banned
okczy21 is an unknown quantity at this point
if you get an aftermarket exhaust system doesnt it just do away the oxygen sensors anyways, why are they there?
okczy21 is offline   Reply With Quote
Old 09-10-2004, 02:44 PM   #5 (permalink)
Sk1d's Avatar
See wat u can do bout gettin sum more info off em... might get lucky...
Good luck...
Me-Chanic
Old 09-10-2004, 05:24 PM   #6 (permalink)
Keep it Copacetic
///M Power's Avatar
Car: 1995 BMW M3
4444444444 O2 sensors? hat's a new one to me. If u got an i6 i didnt think there wud ever be more than 2. hmmmmmm
They are easy to change if u got a u wrench of some sort. You need to give us a year adn a model. And $350 is wayyyyy too $$$$$$$$$ even for canadia
O2 sensors sense the amount of chemicals in ur exhaust waste and thus use a computer to adjust the fuel injection system to provide better gas mileage. YOU NEED IT.
Old 09-11-2004, 08:32 AM   #7 (permalink)
mech9T8's Avatar
OK the dealer told me that bank #2 is the right side of the car but I still don't know if it's the one in front or behind the cat.
I still need to figure out how to tell if the sensor is bad.
Old 09-11-2004, 10:33 AM   #8 (permalink)
/Banned
so do aftermarket exhausts not use the o2 sensors? or do they?
Old 09-11-2004, 11:48 AM   #9 (permalink)
Sk1d's Avatar
Okay, this is where it gets a bit more tricky... If u can get ur hands on a multi-meter u need to check the voltage across 2 of the sensor wires with the sensor still plugged in and the engine warm and running. Not sure wat color the wires will be but u can easily check em all til u get the right 1's. When u probe the 2 correct wires ur meter should show the sensor's voltage switching between about 100 and 700 mV, if the sensor's working correctly...
Hope sum of this helps out...
okczy21, if u bought a cat back system the oxy sensors stay in the system in the original cat' pipe. Dunno wat happens to em if u bought a de-cat pipe tho, sorry...
Sorry guys, tha shoulda been voltage not resistance...
Me-Chanic
Old 09-11-2004, 12:57 PM   #10 (permalink)
69th Gear Member
BeachBunny's Avatar
Car: 1996 328IS
BeachBunny has a reputation beyond reputeBeachBunny has a reputation beyond reputeBeachBunny has a reputation beyond reputeBeachBunny has a reputation beyond reputeBeachBunny has a reputation beyond reputeBeachBunny has a reputation beyond reputeBeachBunny has a reputation beyond reputeBeachBunny has a reputation beyond reputeBeachBunny has a reputation beyond reputeBeachBunny has a reputation beyond reputeBeachBunny has a reputation beyond repute
He's asking $350?! This is just something I remember hearing... but can't you replace your oxy sensors for like 85 bucks?
BeachBunny is offline   Reply With Quote
Old 09-12-2004, 12:18 PM   #11 (permalink)
Henri is an unknown quantity at this point
Ok my dealer told me the same thing on my 318i... I refuse to let them change it since I got no Check Engine light lighted??!!!
I'm from Canada too... the 2 sensors cost 178$ and 75$. The cable is longer, yeah, but the connector is different also... you can't take 2 times the 75$ sensor.
If you can do an oil change all by yourself, you should be able to change those.
http://www.geocities.com/e36rulz/DIY.html
I got a question for you... If I ever realize they were right (assuming I should change these parts), are BMW original oxygen sensor better than Bosch oxygen sensor??
Thanks a lot!
Henri
Henri is offline   Reply With Quote
Old 09-13-2004, 11:36 AM   #12 (permalink)
mech9T8's Avatar
So I crawled under my car this weekend and found all the sensors.
I was able to access the 2 at the rear and I tried to check them for voltage output with a digital multimeter but I didn't get anything conclusive. I have to try the ones at the front now. And this time I'll try to check the resistance too (thanks for the input SK1D). But one thing I noticed is that they are not going to be easy to remove. Wish me luck.
Henri, from my research I believe that the sensors from BMW are Bosch sensors. I've looked around and believe it or not the dealer has the best prices on a new sensor...$178 CAD. You can try to get a used one to if you want. They are cheaper but won't last as long.
Old 09-13-2004, 01:34 PM   #13 (permalink)
Sk1d's Avatar
Me-Chanic
Old 09-14-2004, 04:41 PM   #14 (permalink)
Yeah... that's the 1st time I see cheaper parts at a dealership lol
Anyway, I presume I don't have to change them 'till the Check Engine light is on... right ?
Thanks
Henri
Old 09-14-2004, 04:59 PM   #15 (permalink)
mech9T8's Avatar
Yep.
I read that you should change them after 60,000 miles to ensure good engine performance but I'd wait till you see that check engine light.
Ultimately the choice is yours.
2000 528i 'oxygen sensor adaptation limit' sreitshamer 5-Series (E12,E28, E34, E39, E60) 8 02-14-2012 05:15 PM
Bosch to siemens oxygen sensor swap (inc pics) KILOCHARLIE 3-Series (E36) 9 10-01-2009 07:10 AM
Check Engine Light came on today camnipotent 3-Series (E36) 22 05-17-2004 06:23 PM
New Car - Few Problems, Any Help Appreciated. Sagan 3-Series (E36) 8 05-16-2004 09:28 PM
