OverHeating Problem - BMW Forum - BimmerWerkz.com
Old 12-19-2009, 08:40 AM   #1 (permalink)
blazinaces is on a distinguished road
OverHeating Problem
Ok so I just bought this 92 325i (E36) and the prev. owner was telling me how he had a crack in the radiator but had it fixed or replaced. He also said that he had a problem with keeping water in it, when he said that I was ready to walk away b/c of a probable head gasket problem, but then he said it keeps antifreeze with no prob. but still likes to overheat. Could it still be a head gasket? I've looked around and it doesn't leak, just a lil oil but nothing major. I've noticed a cooling hose going to a pump is all cracked up but surely this couldn't cause this problem. Now I've had this car for about 2 weeks or so and it gets to normal temp. after like 5 mins. If any one has any suggestions or had this happen to them that would be great to see what I'm up against here maybe.
blazinaces is offline   Reply With Quote
Old 12-19-2009, 10:42 AM   #2 (permalink)
Ich bin der Modifikator
johnnyBgood's Avatar
Head gasket? Check for coolant in the oil, remove oil fill cap & look for a tan milky substance, also check & see if there is a sweet smelling mist coming from the exhaust pipe @ operating temperature, it will be a constant white misty smoke ......if not........overheating can result from a faulty t-stat, water pump, or air in the system, which you will need to bleed out.
Signs of a faulty t-stat: coolant circulation too fast, (stuck open) No or very little circulation (stuck closed)......
Water pump: propeller was made out of plastic 92' thru 97' & are known to break apart causing no coolant circulation....
jb
Pelican Technical Article: BMW Water Pump Replacement
BMW E36 Thermostat Removal And Coolant Flush
Old 12-19-2009, 11:26 AM   #3 (permalink)
Texbeamer's Avatar
Car: 1996 BMW 328i
Texbeamer is on a distinguished road
+1
Texbeamer is offline   Reply With Quote
Old 12-19-2009, 05:34 PM   #4 (permalink)
Well I changed a connector hose on the air intake and there was a kinda tan milky substance in there could that be the milky liquid your talking about. Also I have no heat, the windshield trys to fog up when i try to cut the heat on, and when i turn the heat on i smell a hint of antifreeze. All these things i just noticed. Could that be the heater core? B/c I know that on my last car I had that prob., foggy windshield and antifreeze smell and it was the anti freeze.
Old 12-19-2009, 06:14 PM   #5 (permalink)
Is the carpet wet in the front footwell area? This would explain the coolant loss.... Sounds like the heater core!
jb
Old 12-21-2009, 01:21 PM   #6 (permalink)
well i just checked the floorboards and they're not wet, so that is weird, unless on a bmw they have a drain line that goes out of the car. Thats how my last car was. But I know I filled up the reservoir and after a day its completely drained. So I got something going on, just not sure where. Guess on my time off I'll be taking her into a shop so i can actually look at the whole thing. Hopefully its not what I'm not wanting it to be...Head gasket. But that still seems weird that its showing signs of a heater core and maybe it still is the heater core and possibly a head gasket as well. If so then damn I really picked a good one. lol
Old 12-21-2009, 01:44 PM   #7 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
Sounds like you have a heater core problem. You will lose fluid this way and also possibly make your heat not work and smell like antifreeze.
As long as your car keeps a good temp there is no reason to look for a cooling problem. If your care smells like antifreeze inside and your floorboards are wet, you have a heatercore problem.
This will involve removing the dash to fix. Not easy and not cheap.
Good luck,
Les
1997 E36 M3 1990 E30 325i
Old 12-22-2009, 01:26 PM   #8 (permalink)
Good luck,
Les
Oh yeah trust me I know it definitely aint fun, that was one of my 1st problems I encountered on my last car. But my floorboard isnt wet though, so I'm not to sure what it is. I still agree with you, I'm still thinking its the heater core though, i got the next 7 days off so i might check into it during that time.
Old 12-25-2009, 10:47 AM   #9 (permalink)
jeffhall009 is on a distinguished road
Its a big problem for which you should immediately get solved. Other you will find lots of problem while driving your car.
BMW Accessories
jeffhall009 is offline   Reply With Quote
Overheating problem - help? Greg 06'330i 3-Series (E46, E90) 6 09-15-2009 09:24 PM
Overheating problem khmigga 3-Series (E36) 7 07-07-2009 08:59 PM
Overheating Problem. Please Help!!!!! Privateye 3-Series (E21, E30) 6 06-22-2005 01:49 PM
Overheating Problem E36k224 3-Series (E36) 5 03-15-2005 04:58 PM
Overheating Problem mkgbe30 3-Series (E21, E30) 1 10-26-2003 11:03 AM
