» Site Navigation »
» Related Sites
» Buyers Guide
» Network Links
3-Series (E36) Chat relating to the BMW 3-Series from 1992-1999. Autodoodad
07-03-2009, 03:26 PM
#1 (permalink )
Overheating problem
i have a 1997 m3 and i flushed it with my uncle and then ever since it started to over heat. i already replaced the radiator, radiator sensor, thermostat and thermostat housing. what else could be the problem.... Help me out please.
07-03-2009, 03:37 PM
#2 (permalink )
Is the water pump good? Getting all the trapped air out can be a bit hard.
B M W Sig by zeaq
07-03-2009, 03:39 PM
#3 (permalink )
well when i bleed my car it seems fine to release the pressure so im pretty sure its fine. There is no cracks in the water pump either.
07-03-2009, 04:02 PM
#4 (permalink )
I would make sure you know the bleed procedure to a T and maybe have the pump checked and the system pressure tested.
B M W Sig by zeaq
07-04-2009, 08:34 AM
#5 (permalink )
Help from over the pond
Car: E38 1997 735i
Is it fitted with a viscous coupling????
07-05-2009, 07:55 PM
#6 (permalink )
Car: 1998 328is 5 spd black on black
Still sounds like air in the system, get the front up in the air and bleed it again. You should be getting air out not just releasing pressure.
Cosmos schwartz metalic Sparco strut brace 55w 6000k HID w/LED angel eyes smoked Lamin-X blacked out sidemarkers,tails and brakelights. DDM smoked corners and pedals. 35% tint all around, Prosport water temp and oil pressure gauges.
07-07-2009, 08:03 PM
#7 (permalink )
Originally Posted by
jmo69 Still sounds like air in the system, get the front up in the air and bleed it again. You should be getting air out not just releasing pressure.
so i should leave the bleeder closed but open up the cap for the resevoir tank? then run it?
07-07-2009, 08:59 PM
#8 (permalink )
The Stig
Car: 2009 Civic Si, 1990 Miata
Welcome to the world of e36 cooling issues.
I'm sure a search of the forum will turn up what you need. This has been covered at least a couple hundred times on here, no exaggeration.
2009 Honda Civic Si
1990 Mazda Miata
Thread Tools Display Modes Linear Mode
