Overheating Probelms - BMW Forum - BimmerWerkz.com
Old 01-14-2007, 02:12 PM   #1 (permalink)
Cod
Car: 1992 BMW 325i
Cod is on a distinguished road
Question Overheating Probelms
I've had bad overheating over the past month with a little white smoke (can't tell if its from cold weather or what) from the exhaust as well as the smell of anti-freeze inside and outside of the car. From my understanding, white smoke typically means there is a problem with the head gasket or the engine block itself. Like I stated earlier, it has been rather cold here recently and I cannot tell if the white smoke is straight from the engine or just from the car running in the cold. So, is there a way for me to find out whether or not the block is warped, cracked, etc.? I know how to check the head gaskets, but I want to be sure the block isn't shot before going through the trouble of replacement.
From talking to people, I've been told it could be something with the oil on the block, etc.. I was told for that problem to just change the oil and look at the color of it (milky-brownish is bad). Any truth to this?
Also, my car needs a new battery before I do any work on it since its completely dead (lights in car don't turn on, etc.).
Well, any advice or help for anything I've mentioned would be greatly appreciated. Thanks in advance!
EDIT: Forgot to mention the car is a 1992 325i. Thanks!
Cod is offline   Reply With Quote
Old 01-14-2007, 02:33 PM   #2 (permalink)
Sodium Chloride
saltshaker185's Avatar
Car: 95 M3
it sounds like you are burning antifreeze... yes this is common with a bad head gasket but it could also mean that you have a crack in your block that is getting into the cylinders... to check if it is your head gasket change the oil and look to see if it is milky... almost like a milk shake... that will verrify that it is your head gasket... lemme know what you find out...
-salts
93 325i overheating! Insane93E36 3-Series (E36) 9 05-02-2012 12:33 AM
Overheating Gabrielpr12 3-Series (E21, E30) 21 09-23-2005 09:09 AM
Engine Overheating doughnutboy 3-Series (E36) 11 06-13-2005 02:10 PM
Overheating Problem & Stiff Radiator Hose ?? viluve 3-Series (E36) 6 10-30-2004 01:39 PM
