Overheating Please Help - BMW Forum - BimmerWerkz.com
Old 07-22-2009, 01:03 AM   #1 (permalink)
Serge88 is on a distinguished road
I have replaced the bloody head gasket, new gaskets all round etc... the car overheat when idling, no white smoke nothing at all, I noticed when I rev the bugger the needle drops back to centre, bring it back to idle and the needle pegs up... I have a new thermostat, belts and water pump, with new hoses the whole 9 yards... obviously the coolant isn't circulating properly or fast enough... any input would be great. Sere.
Serge88 is offline   Reply With Quote
Old 07-22-2009, 02:05 AM   #2 (permalink)
Help from over the pond
marti5's Avatar
Car: E38 1997 728i Individual
If its not flowing fast enough, its either the waterpump or loose belt, it could also be the stat is the wrong way around or faulty even though its new.
Old 07-24-2009, 09:29 PM   #3 (permalink)
Car: 318i E36 1995
lucky178tb is on a distinguished road
The system must be bled very well...had a similar problem...bled the system properly and all was well ! U probably know where the bleeding screw is but just in case its on top of the radiator...carefull not to overtighten when done as they break easily....if u have already done this and there no air in the system ( which takes a few tries ) then check the fan clutch....this could also be a problem...let us know....gd luck
lucky178tb is offline   Reply With Quote
Old 07-25-2009, 03:03 AM   #4 (permalink)
Guys thanks for the replies, the fucken bimmer is giving me the shits... I have tried 2 different water pumps, 2 different thermostats bled the cooling system so much that there is barely any coolant in there, as it has been overcome by water... no idea what this is I will order a fan clutch and give it a shot, if not I will torch the bugger... will keep posted.
E36 318i overheating and not overheating !!?? lucky178tb 3-Series (E36) 7 07-20-2009 07:16 PM
STILL OVERHEATING - Please Help dnino10 3-Series (E36) 13 12-18-2008 12:17 PM
Overheating Nate Dawg 3-Series (E36) 3 11-08-2007 02:15 PM
Overheating msmartypants 3-Series (E36) 11 01-19-2005 01:49 PM
Overheating. Brian325i 3-Series (E36) 3 11-02-2004 02:44 PM
