Overheating At Idle - BMW Forum - BimmerWerkz.com
Old 07-24-2005, 08:34 AM   #1 (permalink)
BImmerN2B's Avatar
BImmerN2B is an unknown quantity at this point
Hey guys, I have a 318i 5 speed. My car overheats at idle at about 3 min or so of idling without the AC. With the AC on, it would run fine all day. I changed the temperature switch and its still the same. I try to look for this topic and in some places they say it could be a resistor at the Electric fan. Is this something that can be changed or do I have to buy a new fan?
Or what else you guys think it could be?
BImmerN2B is offline   Reply With Quote
Old 07-24-2005, 01:48 PM   #2 (permalink)
Fan Clutch, not the aux fan.
Old 07-24-2005, 02:45 PM   #3 (permalink)
BImmerN2B's Avatar
I thought that my fan was electrical. there shouldn't be a fan clutch
Old 07-24-2005, 02:58 PM   #4 (permalink)
You have two fans, the one you can see in the engine compartment that attaches to the water pump pulley (the viscous fan) and an electric one that is in front of the radiator. If she overheats at idle, odds are it is the fan clutch on the water pump pulley fan. If the electric fan runs with AC on (and it should) then the resistor is good.
Old 07-24-2005, 09:01 PM   #5 (permalink)
BImmerN2B's Avatar
I checked about a fan clutch, but I shoudn't have such a thing. I checked my manual and personally my car and it's an electric fan.
Old 07-24-2005, 09:07 PM   #6 (permalink)
When you open the hood on your car, do you see a fan on the front of the engine?" If yes that is the vscous fan with clutch (the aluminum casting in thecenter of the fan blades either on front or rear of the fan is the clutch) Now, look throught them kidney shaped grill and you will see the electric (auxiliary) fan.
All of our cars have two fans and if the viscous one goes bad, the engine overheats at idle. The electric fan comes on anytime the AC is selected and also has two speeds (low and high) that are triggered by one or two fan switch/es that on your car is/are probably located on bottom, back side of the radiator.
Old 07-24-2005, 10:14 PM   #7 (permalink)
BImmerN2B's Avatar
Thanks for the info Bear. Unfortunately, alll I see is the one in front of the engine. It is not attached to the water pump pulley. In my manual (Yes is the suckey Hanes Manual) says for the M44 it has an electric fan. Could it be that they have a fan clutch too? I thought fans attached to the water pulley had a fan clutch only.
The other issue is I think I got Fucked on the Auxiliary fan, There is no fucking fan there!!!! ghead maybe a dumb ass question, but could that be it. doesn't it come on at Idle?
Old 07-24-2005, 11:47 PM   #8 (permalink)
RallyE36 is an unknown quantity at this point
Have you checked the thermostat or replaced it?
It comes as a single unit with the housing and hose connectors.
1996 E36 M44 318i 5sp LSD
Canadian Model
RallyE36 is offline   Reply With Quote
Old 07-25-2005, 12:39 AM   #9 (permalink)
drz
master of his domain
drz's Avatar
Car: zhp
Thermostat, air pockets, or lose drive belt. Works fine with the AC on because that turns on the auxiliary fan that I will boldly say you do (or at least should) have.
You are right. You don't have a fan clutch problem. M44 e36s and a manual transmission have an electric cooling fan instead of the belt-driven viscous fan. All e36s have a two-speed electric auxiliary cooling fan mounted behind the front grille and in front of the radiator. If you don't have an auxiliary fan, somebody took it out.
Turkey Fleet Bond Holder
Old 07-25-2005, 08:04 AM   #10 (permalink)
Now I am really confused as all parts data bases show a fan coupling (looks like a clutch) for this car. Try www.realoem.com/bmw/select.do then do your car, year, and at search for parts go to engine and then cooling and see if a fan clutch does not appear.
Old 07-25-2005, 03:16 PM   #11 (permalink)
BImmerN2B's Avatar
Well, I'll be I don't have an auxiliary cooling fan. Before in place of it was a fucking neon. I bet they took it out so they could put a silly neon bar in the car.
I will still check the other stuff. Although my belts were changed, new thermo was put in and a flush was done by the stealer. although is funny because I put the A/C on and it's good, but I turn off and that needle will go to RED.
Old 07-25-2005, 03:53 PM   #12 (permalink)
drz
drz's Avatar
Car: zhp
That is really weird. Try to get an aux fan. They are expensive, though. Maybe they wired the primary electrical fan to work on high speed when the AC is on. Just keep the AC on, I guess.
Old 07-25-2005, 04:12 PM   #13 (permalink)
BImmerN2B's Avatar
Here is the setup I got, I got this photo from ebay from where they selling the same fan I have. It came from a 318Ti though, but is the same setup.
Old 07-25-2005, 04:13 PM   #14 (permalink)
BImmerN2B's Avatar
last question I had was if anybody had this setup. especially anybody in the 318 arena.
Old 07-25-2005, 04:19 PM   #15 (permalink)
BImmerN2B's Avatar
OK so I lied, I need the REAL last question. Can you change the resistor on these fans?
Overheating At Idle In Traffic wcre34 3-Series (E36) 7 08-15-2005 09:58 AM
Idle Problems BeelZibub 5-Series (E12,E28, E34, E39, E60) 10 07-10-2005 04:56 AM
Warmed up idle puzzle. nightsurfride 3-Series (E21, E30) 2 02-03-2004 08:04 PM
