| Yes water will come up, there should be a pressure line of some sort to pump the water through the radiator. Most likely your water pump impeller fan cracked which means you need to replace your water pump, a very easy job and while your at it, you should also change out your thermostat and thermostat housing with a metal housing instead of plastic, and a water pump with a metal impeller fan instead of plastic.
__________________ <img src='http://www.european-forums.com/forums/uploads/post-1-1107198379.jpg' border='0' alt='user posted image' />
Formally known as Asio. |
