ops!! now driver side high/low beam wont work - BMW Forum - BimmerWerkz.com
post #1 of 10 (permalink) Old 08-08-2013, 11:24 AM Thread Starter
snyper is on a distinguished road
so previous owner put halos on, but he rigged the wiring so i took it apart to do it right, i accidentatly touched something and the wire arc'ed. put everything back together not high/low beam wont work. i have turn signal and parking lights as well as halo lights up. i tested the wires and i am getting very low power to both high/low instead of correct amount. checked all fuses they are good. i did however blow the ten amp fush for the headlights when the wire arc'ed. replaced the fuse but now no lights...just driver side. passenger side works great.
also im getting codes saying tailight failure and headlight failure....taillights are on and working fine. just the driver side only high/low beam.
so maybe the LCM? i did blow the ten amp fuse so maybe i did more damage furthur up stream???
and ideas? things i didnt check??
as always thanks in advance for any and all help!!
1995 325 is black 2 door, 1999 M3 silver
snyper is offline
post #2 of 10 (permalink) Old 08-09-2013, 01:11 AM Thread Starter
ok heres a lil more info...
i can get one of three working, either the halos, and not high/low, low beam and not high or halos etc...
i know its not the bulbs because i can get them to light up, not the fuses because i checked them all, i am getting no juice to the plug on the harness so its upstream somewhere. so im guessing LCM or maybe a relay?
snyper is offline
post #3 of 10 (permalink) Old 08-09-2013, 02:31 PM Thread Starter
omg, i didnt know it had eight different fuses for headligh functions...
checked all eight this time, found two blown, that was the problem..weird cars..
snyper is offline
post #4 of 10 (permalink) Old 08-09-2013, 03:09 PM
kait_e36's Avatar
kait_e36 is on a distinguished road
Lol! Glad you figured out the issue!
I have a headlight issue myself. I bought the car with HID's. One was out so I bought a new kit...now the same headlight is out! I wonder if the light itself is the problem...
kait_e36 is offline
post #5 of 10 (permalink) Old 08-09-2013, 04:16 PM Thread Starter
Check one of the 8 fuses...fuse goes to each light high and low beam
snyper is offline
post #6 of 10 (permalink) Old 08-14-2013, 01:20 AM
Honolulu is on a distinguished road
Yeah it always helps to RTFM. "Read the factory manual" or Bentley, whichever is handier.
This rings for me b/c suddenly none of my headlights on the '95 vert will work. They were okay the other day, but I pulled all the fuses for inspection, they were all good, now no headlights. It's dark now, but apparently there is a headlight ground on the front of the left front fender. A fail there would presumably kill the lights, so I know where I'm going first thing tomorrow: under the hood again. Such fun!
Honolulu is offline
post #7 of 10 (permalink) Old 08-14-2013, 01:46 PM Thread Starter
I'm new to these cars so I'm still learning the ins and outs. I'm getting a taillight failure signal from computer when I turn on lights but they are all working fine. so now I'm researching that....
snyper is offline
post #8 of 10 (permalink) Old 08-14-2013, 03:27 PM
kait_e36's Avatar
Do you guys have any issues with after market tail lights? I bought the car with the smoked ones and the right side keeps going out....
kait_e36 is offline
post #9 of 10 (permalink) Old 08-14-2013, 06:16 PM
4DoorWhore
Lord Vader's Avatar
Quoted: 1 Post(s)
After market tails arent made as well as OEM. The tailight has a metal circuit board behind where the light socket plugs in. Take the light out and inspect it to make sure its still intact. Make sure the bulb sockets are seated properly.
For those with headlight issues: Their is also a relay that controls some headlight functions. Being in Canada I have a DRL module, but US spec cars have a different relay in its place behind the steering column.
And Follow Me on Instagram @E36M52
Founding Member of the Canyonrot Club! Paint Code #343
| OE M3 Bumper | M3 Mirrors | Max Velocity GTR Lip | Euro ZKW Projector Headlights | Jim Conforti CF CAI | UUC Motorwerks Underdrive Pulleys | 18x8 ASA AR1's | Koni Sport Springs & Shocks |
Lord Vader is offline
post #10 of 10 (permalink) Old 08-15-2013, 02:24 AM Thread Starter
I found there's two fuses for overall headlight and also a separate fuse for each side high beam and each side low beam. Changed fuse and low came on and ditto for high beam. Wish I knew there were eight fuses for the headlights.... Checked downloaded Bentleys and fixed it after checking the other fuses. I'll pull taillights tomorrow. Would third brake light in spoiler cause taillight failure warning?
snyper is offline
Low beam headlight working on one side only L0KITH3J3ST3R 3-Series (E21, E30) 0 04-22-2011 05:25 PM
need help asap... low beam wont work on driverside... 98blkm3 3-Series (E36) 3 07-22-2010 03:19 PM
Headlight problem: City lights don't work (low and high beam do) KILOCHARLIE 3-Series (E36) 4 09-21-2005 02:33 AM
Side lights don't work (dipped and full beam do) - please help!! KILOCHARLIE 3-Series (E36) 5 09-17-2005 02:35 PM
High low beam KDM323i 3-Series (E46, E90) 0 11-24-2003 05:53 AM
