| Yes, go M3 bushings, you dont want them failing again soon now do you? Besides, the flex that the stock ones give you is unwanted, wheel alignment will actually change during hard cornering or hitting bumps in the road since those bushings flex so much.
If you havn't done so yet, replace your RSM's and get reenforcement plates (or just a rear crossbar with enforcement plates - even better) since the sheet metal around the rear strut tower is known to tear and fail, esp. if you have stiff suspinsion and drive your car hard or on bumpy surfaces.
__________________ |
