one cylinder blown and no compression - BMW Forum - BimmerWerkz.com
post #1 of 15 (permalink) Old 06-04-2004, 01:01 PM Thread Starter
steviebhoy is an unknown quantity at this point
this is the diagnosis from the mechanic...is this a common problem on 318's with 120K miles that have been well maintained?
Am getting suspiscious about this mechanic and reckon he may be causing more trouble than he is fixing.
steviebhoy is offline
post #2 of 15 (permalink) Old 06-04-2004, 01:27 PM
Super Moderator
dutchbmw's Avatar
dutchbmw has a reputation beyond repute dutchbmw has a reputation beyond repute dutchbmw has a reputation beyond repute dutchbmw has a reputation beyond repute dutchbmw has a reputation beyond repute dutchbmw has a reputation beyond repute dutchbmw has a reputation beyond repute dutchbmw has a reputation beyond repute dutchbmw has a reputation beyond repute dutchbmw has a reputation beyond repute dutchbmw has a reputation beyond repute
You mean the piston? Also the cylinder surface is damaged I guess, so look at the junk yard for a new engine. Upgrade 318i --to--> 328????? :P
BMW '96 M3 (SOLD
June 2005 Car Of The Month!
Originally Posted by Torque
dutchbmw is offline
post #3 of 15 (permalink) Old 06-04-2004, 02:28 PM Thread Starter
Your joking this engine is fecked?
post #4 of 15 (permalink) Old 06-04-2004, 02:33 PM
Bengali86's Avatar
Bengali86 is an unknown quantity at this point
Send a message via MSN to Bengali86
you can always pay HELLA to have a mechanic repair your current engine, or pay about the same amount and upgrade to 2.5L or 2.8L engine_ of corse that calls for some rewiring who doesnt love that
1993 e36 325is
AC Schnitzer Exhaust
AC Schnitzer type I full body kit
AC Schnitzer chip
A monkey in the trunk (stock)
Dual V-Tec
Bengali86 is offline
post #5 of 15 (permalink) Old 06-04-2004, 02:43 PM
Super Moderator
dutchbmw's Avatar
No compression to one cylinder means a mechanical problem. The cylinder block is milled in one piece and if the surface is damaged the only way to repair this is taking out the engine.
What kind of advice is your mechanic you given?
BMW '96 M3 (SOLD
dutchbmw is offline
post #6 of 15 (permalink) Old 06-04-2004, 04:47 PM Thread Starter
so the official word from the mechanic is a piece of metal was found rattling around the engine. 2 valves gone. he suggests it may have been sucked in through the manifold?
this guy worked on the car 3 days ago to replace a couple of belts and is now wanting $1550 to fix this problem.
am i lucky here or being taking for a ride?
post #7 of 15 (permalink) Old 06-04-2004, 07:58 PM
If you're paying that much for a rebuild, might as well find another used 318 motor. It's only $1000-$1500 for a low milage one.
Bry
<a href='
target='_blank'>- VIEW MY MODS AND PICS</a>
<a href='
target='_blank'>- PARTS FOR SALE</a>
&lt;img src=&quot;
Autotechnica is offline
post #8 of 15 (permalink) Old 06-04-2004, 09:31 PM
CiscoKid's Avatar
i tihnk he did this to pump money out of you... ask to see the metal piece, and the damage
CiscoKid is offline
post #9 of 15 (permalink) Old 06-04-2004, 09:34 PM
skawful's Avatar
skawful is an unknown quantity at this point
Send a message via AIM to skawful
replacing the 1.8 litre with the 2.5 litre would require new springs and maybe even brakes...
along with some more crap
<img src='http://img259.imageshack.us/my.php?image=sig8hw.jpg' border='0' alt='user posted image' />
skawful is offline
post #10 of 15 (permalink) Old 06-04-2004, 10:16 PM
like rear diff
a tranny would be a good idea too....
2008 128i Jetblack
007ben is offline
post #11 of 15 (permalink) Old 06-05-2004, 02:34 AM
Exhaust, shocks and struts, springs, custom repositioned engine mounts plus everything mentioned above. You know for the price of a 6 cyl motor swap into a 318 you could practically buy a used 325.
Bry
<a href='
<a href='
&lt;img src=&quot;
post #12 of 15 (permalink) Old 06-05-2004, 02:38 AM
Mark31186 is an unknown quantity at this point
Send a message via AIM to Mark31186 Send a message via Yahoo to Mark31186
Yup. Buying a bigger engine sounds good and all but suspension will definately be needed to support the weight along with handling since u got more weight up there that wasnt there before. Lots of hidden costs there
-Mark
<span style='color:red'>- Conforti cold air intake
-Triflo exhaust
-Clear corners and tails
-Custom wheels
-Racing Dynamics stress bar
-UUC short shift kit
-Turnermotorsport Performance Chip
Soon to come - Zimmerman brakes, and suspension AND UMNITZA DDE IF I EVER GET THE GODDAMN MONEY
</span>
Mark31186 is offline
post #13 of 15 (permalink) Old 06-05-2004, 02:46 AM
e285er is an unknown quantity at this point
Dude 1500 for a couple of valves. There is no way that the "metal piece" damaged the piston so for some head work and maybe some machining...1500 is too much. I got my entire head rebuilt for only 2500 with machining. He is pulling your leg. Dont let him get away with it. Have a look for yourself. And about a larger engine, have fun with that. It isnt as easy as these guys are saying!!!Good luck!
e285er is offline
post #14 of 15 (permalink) Old 06-05-2004, 10:47 AM
we never said it was easy.
2008 128i Jetblack
007ben is offline
post #15 of 15 (permalink) Old 06-05-2004, 11:27 AM
Super Moderator
dutchbmw's Avatar
Go for a new engine, a good used one. I think the cylinder surface and piston are damaged too. It's more than only renew the 2 valves I guess.
BMW '96 M3 (SOLD
dutchbmw is offline
