Oil & water use.... - BMW Forum - BimmerWerkz.com
Old 01-24-2007, 11:23 AM   #1 (permalink)
CL30131 is on a distinguished road
Oil & water use....
Hi guy's & girls...
I just (in December) bought a 318i (1994) and since have driven it about 3000km. It only had 144000 on the clock so ZAR 40000.00 was not a bad buy, but... If come to realise "he" uses about a pint (500ml) of oil every 500-1000km and also a bit of water. That's about the usage I had on my old 518i (1983), even worse actually... What's normal for this car, provided the hot driving conditions of South Africa (in the last week we had about 45 degrees celsius/113 degrees fahrenheit) I'm also a bit of a "fast" driver, with the last 1500 hitting 140-150km/h every now and then, with the occasional 200km/h.
CL30131 is offline   Reply With Quote
Old 01-24-2007, 01:11 PM   #2 (permalink)
BMWJNKY's Avatar
Car: '89 E30 w/M50
The oil usage is normal, also you have to keep in mind that higher RPM use will use more oil. As far as the coolant loss, you may just need a new radiator cap. A leaking cap is a somewhat common issue on the BMW's, the cap won't leak enough to allow coolant to drip out but it leaks enough where it won't keep the steam in. I'd say put a new cap on on the radiator and maybe try to get some Liqui Molly engine treatment.
My M50 Powered E30 Page
Old 01-25-2007, 12:07 AM   #3 (permalink)
Cool, thanx for the advice. What Liqui Moli treatment? I'm down in South Africa... and we don't have anything like that.
Old 01-25-2007, 12:37 AM   #4 (permalink)
BMWJNKY's Avatar
Car: '89 E30 w/M50
The brand is Liqui Molly and on the bottle it just says Engine Treatment. Maybe try and get some online. Liqui/Lubro Molly makes a good product that is somewhat popular in European shops so it shouldn't be too hard to find.
Old 01-25-2007, 12:40 AM   #5 (permalink)
Thanx. Have you got any idea what an original radiator cap would cost? Just wanna compare prices.
Old 01-25-2007, 01:51 AM   #6 (permalink)
BMWJNKY's Avatar
Car: '89 E30 w/M50
At the BMW shop I work at we sell the cap for about $15 USD, not sure what the dealer charges.
Old 01-25-2007, 01:56 AM   #7 (permalink)
$15 is ok... that's about ZAR105.00
Old 01-25-2007, 10:01 AM   #8 (permalink)
What weight oil are you using?
What weight oil are you using down there? I would hope at least a 20w-50 or something like that. Most of the time it's just the O-rings on the radiator caps that go bad. They are easily replaced (at least in the States that is...). Any other temperature problems?
-Mike
Hamfisted is offline   Reply With Quote
Old 01-25-2007, 11:06 AM   #9 (permalink)
Hi Hamfisted...
Yep, using multigrade (that's what we call it 20w-50). No real temperature problems. He stays steady at "mid" range, even during 45 degrees celsius ( 113F) the other day. Between a tank-fill of petrol (gas) he'd use about a liter to liter and a half of water. Will have a check on that cap later.
Old 06-13-2007, 02:23 AM   #10 (permalink)
The cap seems to have solved the problem...
But now... if done another stupid thing. I haven't checked the oil for some time - ran it below the dipstick. I filled up about 1.5liters yesterday! What I first thought was the exhaust noise seemed to have been engin noise. He's running smootly again, but my question is how much damge did I cause the engin. The oil light never came on, while temp stayed at mid range, so he did not overheat or anything.
Do you guy's know how the oil is distributed inside the engin? When the level goes down, what get the least oil first? The timingchain maybe?
Oil drain plug *HELP* topless_328 3-Series (E36) 15 12-06-2006 04:10 PM
oil leaking from a few places... yammahamma 3-Series (E21, E30) 31 11-02-2006 10:28 PM
Oil additives and the damage they do. Starmavin 3-Series (E21, E30) 2 05-18-2006 01:49 AM
