Oil Reset Light - BMW Forum - BimmerWerkz.com
Old 11-16-2004, 12:21 PM   #1 (permalink)
bmwdude's Avatar
bmwdude is an unknown quantity at this point
ghead ok ive read all the posts but i cant seem to get my light to go out after i had the oil changed on my 1999 323is (E36) i followed the instructions using a copper speaker wire a paper clip but still no luck anybody else have trouble doing theyr's?
need all the help i can get.
thanks
bmwdude is offline   Reply With Quote
Old 11-16-2004, 12:50 PM   #2 (permalink)
frank3 is an unknown quantity at this point
I've found it to be hit and miss. Usually a few trys..ensuring that you have a good connection at both ends...and it finally works.
<span style='color:green'>1994 325i </span>- - - 75,000 mi.
No mods - - - very happy as is!
<span style='color:green'>1995 525i </span>- - - 154,000 mi.
No squeaks or rattles... unreal!
frank3 is offline   Reply With Quote
Old 11-16-2004, 07:08 PM   #3 (permalink)
Threadkiller
bitcore's Avatar
it didn't work the first time I did it.
put the wire in, there's a ground pin and a pin you short. They are really close to each other so the paperclip works fine. (bend the leads backwards into a U shape so they fill the little barrel plugs) Turn the ignition to the ON (run) position (not just accessory) and let it sit there for 15 seconds. Turn it off, remove paperclip, and turn it back on.
If it dosn't work, then just live with the lights.... They are only lights, nothing more.
Old 11-17-2004, 04:02 AM   #4 (permalink)
BLACKBMW's Avatar
BLACKBMW is an unknown quantity at this point
Here's how I did mine - it took me 2 goes too!
Make sure you select the correct pins
Make sure you get the paperclip to connect with the side of the pins - NOT the bottom of the pins
Then two clicks with the key (DONT START IT)
I waited 3 (three) seconds then jumped out and pulled the pin
When I got back in all my lights were reset
bingo bango - all done!
good luck
<img src='http://img.photobucket.com/albums/v629/BLACKBMW1/alssig.jpg' border='0' alt='user posted image' />
Thought for the day: &quot;d'uh&quot;
BLACKBMW is offline   Reply With Quote
Old 11-17-2004, 02:49 PM   #5 (permalink)
DesmoBob's Avatar
be careful about the timing. 4 seconds is all it takes to reset the oil light.
if you go longer than 10 seconds, you can inadvertently reset your inspection i/ii interval.
Reset Check Engine Light BMWDriver86 3-Series (E21, E30) 10 01-17-2005 08:22 PM
Need To Reset The Srs Panel Light DonnyY 3-Series (E36) 1 12-01-2004 03:21 PM
Newbie Help Please 2002 325xi Reset Service Light. TRI916 3-Series (E46, E90) 1 11-13-2004 01:55 AM
Brake Lining Light reset ZOOMER9 5-Series (E12,E28, E34, E39, E60) 1 12-09-2003 08:40 AM
