oil in plugs! - BMW Forum - BimmerWerkz.com
Old 09-06-2004, 07:50 PM   #1 (permalink)
jayg
Guest
Posts: n/a
im sure this has already been posted many times before, but i can't find it. oh well. any kind of round about head gasket replacement cost(east coast)? it can probably wait a while, but my e-36 is like my balls. gotta take care of your balls.
Old 09-06-2004, 08:35 PM   #2 (permalink)
Kevin325i's Avatar
It's a valve cover gasket. If you can change your oil wtih your dominant hand tied behind your back, you can change it yourself.
Kevin (President TBEA)
Old 09-06-2004, 08:51 PM   #3 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
Thats the greatest analogy I've ever heard...
Yes.. buy a Valve Cover Gasket kit.. replace it... and you should be fine.. That kit should come with O-rings too.... Werd!
Les
1997 E36 M3 1990 E30 325i
Old 09-06-2004, 09:13 PM   #4 (permalink)
ajames is an unknown quantity at this point
I agree with replacing the Valve Cover Gasket
but on a side note ... i thought some oil in that area around the spark plugs was perfectly natural. I recall reading that in the instructional on how to change your spark plugs on pelicanparts.com
i believe it said that some oil in there is perfectly natural.
any insight on that?
<span style='color:blue'>1992 325is
I think i'm in love ...
&quot;Racing in a honda is like racing in the special olympics ... even if you win, you're still retarded.&quot;</span>
ajames is offline   Reply With Quote
Old 09-06-2004, 09:17 PM   #5 (permalink)
Car: 00 Prelude, 95 525i, 85 635CSi
d3ity will become famous soon enoughd3ity will become famous soon enough
JUST had the same problem.... Valve cover gasket fixed it easily, plus, while your in there, degrease your valve cover, if you really want you can paint it as well!
<iframe src="http://gamercard.xbox.com/TiddlyPlatypus.card" scrolling="no" frameBorder="0" height="140" width="204">Put your gamertag here too.</iframe>
d3ity is offline   Reply With Quote
Old 09-06-2004, 09:25 PM   #6 (permalink)
Kevin325i's Avatar
It's not normal. They say that it doesn't seem to affect performance.
Old 09-07-2004, 03:34 PM   #7 (permalink)
jayg
Guest
Posts: n/a
thanks. i meant valve cover gasket. it still runs like a champ, though.
Old 09-07-2004, 10:38 PM   #8 (permalink)
gaijin1 is an unknown quantity at this point
If you buy the gaskets from Pelican, be aware that the Spark Plug Gaskets don't come with the Valve Cover Gaskets.
Ask me how I know...
Fred
gaijin1 is offline   Reply With Quote
Old 09-08-2004, 10:35 AM   #9 (permalink)
Regnout
Guest
Posts: n/a
I just replaced my valve cover gasket a few weeks ago. Pretty straight forward since I use the DIY from Pelicanparts.com. I went to the dealer and got the valve cover gasket which included the spark plug gaskets. I paid around $39. While I was in there, I replaced the plugs too .
Old 09-08-2004, 06:28 PM   #10 (permalink)
jayg
Guest
Posts: n/a
that's the plan- i just replaced the plugs when i found out there was oil in 'em. but i'll do it again if i got to. the set is on its way from bav auto. until then it's parked. ghead
Changing Oil Filter Housing Gasket and O-Ring Live_the_Curves 3-Series (E36) 8 04-25-2010 01:34 PM
98 BMW e39 oil filters for sale!!!! chgolatin2 OEM Parts 0 09-18-2005 12:03 PM
