oil and pads...and alignment - BMW Forum - BimmerWerkz.com
Old 07-05-2004, 05:03 PM   #1 (permalink)
brien4787's Avatar
brien4787 is an unknown quantity at this point
Send a message via AIM to brien4787
how much do you think its going to cost me to get my brake pads replaced, and oil changed?
also, i need to have my alignment checked or just have tires rotated or somthing because my car isnt going straight all the time... how much do you think this will run me?
brien4787 is offline   Reply With Quote
Old 07-05-2004, 05:11 PM   #2 (permalink)
Threadkiller
bitcore's Avatar
Alignment fixes the car not traveling stright and always wanting to turn a certain direction. Great prodecure to do and it revitalizes your car's steering abilities since one wheel isn't all crooked. Tire rotation is to keep tread wear even, you want the most tread in the front to give you best traction in the rain & corners.
Oil change oughta be pritty cheep, like 20$, jiffy libe charges 40$ and checks all of the fluids and tops them off as nessicary for free.
Brake pads varry, for OEM, I'm betting 30-60$ each pad. For good pads, like axxis, expect to pay a little more.
Get alignment. If you have a vibration, get them balenced. If your tread is less in the front than the back, get a rotation. Check your air filter while you're at it.
Old 07-05-2004, 05:15 PM   #3 (permalink)
brien4787's Avatar
i just checked out my air filter. i am not sure when you need to replace that though. it was replaced a few months ago. what will it look like when it needs to be replaced?
Old 07-05-2004, 05:23 PM   #4 (permalink)
Kevin325i's Avatar
Dirty, full of dust and crap, blackish color.
Kevin
Kevin (President TBEA)
Old 07-05-2004, 06:04 PM   #5 (permalink)
Threadkiller
bitcore's Avatar
at a very minimum, about once a year. I take mine out and shake it clean occasionally, althought I need to just get a new one. Replace it really whenever you think it's starting to block airflow, which occurs when it really isn't that dirty.
